| | #1 |
| Junior Member Join Date: Jul 2007
| '62 Tremolux nasty oscillation on power up
Hi, I have a friend that bought an old '62 Fender Tremolux (6G9-B) that he wants to revert back to stock. Some hack put in a Super Reverb type power tranny and choke, and a Twin output transformer. Also, aforementioned hack attemtped what looks like a negative feedback control or effects loop of some kind Here are a couple of before shots: http://img.photobucket.com/albums/v3...B/trem1_b4.jpg http://img.photobucket.com/albums/v3...B/trem2_b4.jpg http://img.photobucket.com/albums/v3...G9-B/pi_b4.jpg Looking at the amp and referencing a schematic, I figured I could help him get his amp back to stock (having worked on a few Fenders of my own successfully). Here are some shots of the amp stripped of the unoriginal pieces: http://smg.photobucket.com/albums/v3...G9-B/trem3.jpg http://smg.photobucket.com/albums/v3...G9-B/trem4.jpg He purchased a Mercury Magnetics power tranny FBLT-P (based on the original #68409) and output tranny FBLTR-O (reference http://www.mercurymagnetics.com/page....htm#Tremolux_) in an attempt to get the amp back to its former self. I installed them in the amp and also replaced the filter capacitors. I also noticed that some of the resistors in the phase inverter look to have been replaced by I guess the aforementioned (having incorrect values and obvious signs of resolder). Referencing the schem, it looks like the 4700 ohm resistor was at one point a 100 ohm resistor, the 6800 ohm resistor was at one point an 82k ohm resistor and the 820 ohm resistor was at one point a 470 ohm resistor. I replaced all of these according to the schematic. I did notice something weird between the layout and the schem, the feedback resistor on the 6G9-B layout denotes 56k, whereas the 6G9-B schematic says 100k. My friend's amp is an 82k, and *looks* to be original, but it's hard for me to say. Just thought that was weird... not sure if 82k would make a difference here? Also, I noticed that the 0.0001uF cap across the two PI plates as shown on the layout and schematic is missing from the amp and doesn't appear it was ever installed there as the solder joints look untouched (!). Anyway, so I powered the amp on and I notice that as soon as it warms up, there is a horrible squealing coming out of the speakers. I have a clip of it (m4a/AAC audio file recorded on my iPhone, playable in WinAmp and I am sure other media players). You can hear my power on, the tubes warm and the squeal comes in at around 0:14 whereby I immediately shut off the amp: http://rapidshare.com/files/297631831/Squeal.m4a.html OR http://www.megaupload.com/?d=GJOZWI62 So, I pulled the phase inverter (even the power tubes, for that matter) and the sound goes away, so it seems to be isolated to that stage. Yes, I wired the OT primary correctly. Even flipped the wires and got a motorboating sound so I reverted it back. The voltages are consistently a little high throughout the amp (10-20%, I've got 120VAC coming out of the wall), so there's nothing indicative to me regarding the DC voltages for the various tubes. Here's the after shots (maybe someone will spot something obviously wrong?): http://smg.photobucket.com/albums/v3...-B/trem5_a.jpg http://smg.photobucket.com/albums/v3...-B/trem7_a.jpg http://smg.photobucket.com/albums/v3...-B/trem8_a.jpg http://smg.photobucket.com/albums/v3...-B/trem9_a.jpg http://smg.photobucket.com/albums/v3...B/trem10_a.jpg http://smg.photobucket.com/albums/v3...B/trem11_a.jpg Is there a cap in the PI that could be bad? How does my layout look? Any suggestions welcomed and appreciated. Thanks for your time, Chris |
| | #2 | |
| Member Join Date: Apr 2009
| Quote:
From what you've described the power section works. Does the volume control have any effect on the volume? That could narrow it down even further. Did the amp work at all when your friend got it? Did your friend buy this amp as a project that somebody gave up on? I have had a couple amps that were like that-nobody could figure our how to fix em so they get passed around. There's no real answer except start from scratch, because 9 times out of 10 the problem we encounter can be traced back to the last person who was in there. That implies no disrespect, it's just a fact of troubleshooting, which is really an application of probabilities. I think if I was you I would locate the guy who did the "mod" and break his knuckles-that hole in the chassis is hideous. | |
| | #3 |
| Supporting Member Join Date: May 2006 Location: Texas USA
Disconnect the 100K (or 56K) feedback resistor and see if that kills the squeeling. Looking at the pdf file for the 6G9-B on Schematic Heaven the schematic says 100K and the layout says 56K. This tells me there was problems in that circuit and changes were made to try to fix it. Normally the higher value would tend to be the one that didn't oscillate. YMMV. Does the amp have 0.1uF caps between the PI and power tubes?
__________________ WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personel. |
| | #4 | |||
| Quote:
Quote:
Quote:
No disrespect taken, I wasn't the one who F'ed this amp up! Preach on, brutha! | |||
| | #5 | |
| Quote:
What I did before I read your post was simply unsolder the lead that comes off the output jack that connects to the 82k resistor (100k on the schematic, 56k on the layout) on this amp's board. And guess what? No oscillation. Maybe I'll try a 100k there and see what happens? Yes, the amp has the two blue 0.1uF caps as it leaves the PI for the 6L6s... Thanks for your help. I'll let you know what I find when I get a chance to check it out again in the next few days. | |
| | #6 | |
| Quote:
It sort of simplifies things a lot, though, when you figure that your problem is somewhere in a 10 inch x 24 inch piece of real estate. Plus you've got some dandy iron to play with now. | |
| | #7 |
One thing jumps out at me as being wrong. You have changed the NFB load resistor to 4.7K from the 100ohm that was in there, BUT the NFB dropping resistor is stil 820ohms. Either go back to 100ohms for the NFB load, or up the value of the NFB dropper to 27K/56K.
| | #8 |
"BTW, it looks like the 82k resistor replaced whatever the original one was when the butcher modified the amp with a master volume or some kind of NFB control..." There is no 82K resistor in the NFB loop, grey/red/brown = 820ohms
| | #9 | |
| Quote:
Re: the inartful work, I think whoever did this just used what they had. Not trying to justify the damage done, but no one back then imagined they'd be ruining a "vintage amp"... | |
| | #10 |
Re: the "82k", you're right. It was a 820 ohm resistor. I saw the layout diagram had 56k and the schematic had 100k and then I saw the grey and red bands on the resistor and for some reason ignored the brown band and in my mind concluded it was an "82k"... I'm getting old... To make it a little simpler to understand, I've marked on this schematic in red what the resistor values were before I started working on the amp: http://img196.imageshack.us/img196/3...emolux6g9b.gif Yesterday I replaced the NFB dropping resistor with a 100k as per the schematic and it still oscillated, though not so bad (a little more quieter). It seem to be more of a motorboating type of oscillation (slower cycles) than a squealing, though there was still a little squealing. So it seems like what I can do is to try a 56k for the NFB dropping resistor and see what will happen, although if what loudthud said is true, it probably would still oscillate with the 56k if it did with the 100k (?). Or I can put the 820 back and change the load resistor to 100 ohm. This would be deviating from the schematic, though... I'll report back in a few days unless someone else has some words of wisdom to schlep my way... Thanks for the help! |
| | #11 |
| Senior Member Join Date: Dec 2007
I have a bone stock 63 Tremolux in mint condition. As far as I know it has never been touched except to replace a few tubes. If a few gut shots would help you let me know. I'm not sure if I could do it instantaneously but at certainly in the near future if you still need a reference point.
| The Following User Says Thank You to olddawg For This Useful Post: | seven (10-28-2009) |
| | #12 | ||
| Site Janitor | Quote:
Quote:
__________________ -tb | ||
| | #13 | |
| Quote:
Note that while I reverted some of these resistors back to what the 6G9-B schematic indicates, I didn't revert the 820 back to a 100k (or 56k). OK. What do you think the problem is? Or are you saying you're not sure what it is, but that it's probably not with the PI? | |
| | #14 | ||
Quote:
Since the oscillation stopped when you disconnected the NFB, I'd be inclined to try swapping the OT primary leads again, now that you have the correct values in the feedback loop.
| | #15 |
+1 on Tboys suggestion.
| | #16 |
OK, I've been meaning to reply to this last week, but forgot. After restoring the 820 NFB dropping resistor to 100k, I still got oscillation. At this point, it just didn't make sense why the amp still oscillated. So I tried something that in my mind was crazy: I swapped the primaries on the OT. Oscillation is gone! Yes, I know many of you are rolling your eyes now. But I followed the MM wiring diagram and the official Fender layout diagram wrt the wire colors on the respective plates. I guess somebody at Mercury Magnetics was winding that output transformer at 4:50pm on a Friday... They were either tired OR thinking about ![]() Needless to say, the amp is sounding great. Probably the best it's sounded in 35 years, given the EIA codes on all the previous components the "butcher" put in. Thanks again for your help. I learned a lot. |
| | #17 |
Following the wiring diagram means nothing when it comes to OT primaries...even when fitting say a later, Vibrolux OT to a Tremolux you may have to reverse primaries, lost count of the number of RI Bassmans I have seen with switched OT secondaries....if you have to reverse them, then you just have to reverse them
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Acoustic 370 oscillation in power stage | Mars Amp Repair | Maintenance, Troubleshooting & Repair | 14 | 05-15-2009 10:38 PM |
| Bad power tube or oscillation? | 6267 | Maintenance, Troubleshooting & Repair | 5 | 10-22-2008 03:36 PM |
| nasty fuzz noize | eruannu | Tweed Builders | 3 | 01-17-2008 04:18 PM |
| Renown 400 Nasty Noise | kn6xu | Maintenance, Troubleshooting & Repair | 2 | 02-25-2007 07:16 PM |
| Fuzz Face clone being all nasty-like | Arthur Dent | Guitar Effects | 4 | 10-30-2006 10:36 AM |
