Go Back   Music Electronics Forum > Amplification > Guitar Amps
Guitar Amps General discussion about amps
Old 10-27-2009, 03:24 PM   #1
vibrolux cuts out after long use
I have a silverface vibrolux that after a set of use cuts out.It sounds like a tremelo,but only once....the volumn drops then comes right back up,any help would be appriciated thanks fester g
fester gomez is offline   Reply With Quote
Old 10-27-2009, 03:44 PM   #2
If it's always OK when you fire the amp up, it's probable that something is getting hot & failing. Volume returns when things have cooled down.
Do you see any red/orange glow in the grey/black metal plates inside the power tubes? I don't mean yellow points of light, or blue/purple gassy glow. Knowing what bias current the tubes are set to would be helpful. Has the amp been service to your knowledge.
MWJB is offline   Reply With Quote
Old 10-27-2009, 07:56 PM   #3
Supporting Member
loudthud's Avatar
Does smacking it with your fist have any affect?
__________________
WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personel.
loudthud is offline   Reply With Quote
Old 10-28-2009, 04:11 PM   #4
thanks for the replies,the volumn returns almost immediately after it drops,it has to be hot for a extended time before it acts up
Old 10-28-2009, 05:07 PM   #5
Too much plate current on the power tubes will make it hot quicker than anything else, so any answers to my previous questions?
Old 10-29-2009, 02:52 AM   #6
tubes seem fine,just biased, can't recall what they're set at,caps were replaced in past couple years.
Old 10-29-2009, 02:45 PM   #7
Does the sound fade smoothly out over a few seconds, or just stop dead?
pdf64 is offline   Reply With Quote
Old 11-15-2009, 11:02 PM   #8
i just got it to do it again, it cuts out tonally,there is still volumn but it sounds thin.Also if you hit the top of the amp it will act up too.Had a scope on it all looked good then as you turned it up it would start to clip,then the signal would get really scrambled,and stayed like that.
Old 11-16-2009, 12:54 PM   #9
Is this on both channels?
I'm not a big fan of hitting amps, but this suggests a loose/broken component/pot, something shorting in certain conditions. Thorough visual inspection might help.
"Had a scope on it all looked good then as you turned it up it would start to clip,then the signal would get really scrambled,and stayed like that." this is a bit vague, at what sort of W output does this scrambling start, what poin in the circuit does this scrambling show up?
Old 11-16-2009, 03:42 PM   #10
yes it is on both channels,all caps,filter & coupling are recent.I changed out power tubes,phase inverter tube and rectifier tube,also swapped around pre's.At first i was running through a bandmaster cab,closed back,and it was not as noticable as through the open back cab,were it sounds more pronounced.When a chord is struck and sustains you can hear the signal over distort as it rings out.The pots seem good when measured against each other.There aren't any components that even look suspect.
Old 11-16-2009, 03:54 PM   #11
If it's on both channels it's at the phase inverter/power section. I am assuming there is no Master vol, added or, otherwise. Check dc voltages at power tube (pins 3, 4 & 5) & V6 (pins 1, 6, 8) sockets.
Check speakers & wiring.
Acoustic 470 cuts out. bowesj Maintenance, Troubleshooting & Repair 4 04-22-2009 12:10 AM
Stage 112 cuts in and out deluxe reverb92 Maintenance, Troubleshooting & Repair 3 05-07-2008 10:28 PM
Ampeg J12T cuts out after heating up dporto Maintenance, Troubleshooting & Repair 34 12-22-2007 03:32 PM
Ampeg J12t cuts out Marc Maintenance, Troubleshooting & Repair 6 12-11-2007 10:01 PM
peavey 300 cuts out stefan Maintenance, Troubleshooting & Repair 1 03-27-2007 03:10 AM
