| | #1 |
| Junior Member Join Date: Jul 2009
| 5C1 Power Resistors
The parts list I have specifies 2-500ohm 10watt power resistors........can 5 watt resistors be SAFELY used????? Those 10 watt resistors are HUGE!!!!! Thanks. |
| | #2 |
5W will be fine for both resistors. Likely voltage drop accross both will be in the region of 20-30vdc @ <60mA, allowing for relatively high B+, therefore 30v*30v= 900. 900/500ohms = 1.8W dissipation.
| The Following User Says Thank You to MWJB For This Useful Post: | dtjacob (10-28-2009) |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| 5C1 Resistors | dtjacob | Tweed Builders | 6 | 10-20-2009 10:52 PM |
| Do bleeder resistors waste power? | Gaz | Theory & Design | 14 | 06-08-2009 08:23 AM |
| Now I need help with the resistors for a fender 5c1 amp :/ | rdstang01 | Build Your Amp | 2 | 03-08-2008 10:18 PM |
| SS amp with Burning Resistors at Power-Up | bob p | Other Amps | 7 | 07-25-2007 08:39 AM |
| 5C1 ...of sorts | andrew4566 | Tweed Builders | 2 | 12-11-2006 04:14 AM |
