Go Back   Music Electronics Forum > Music Electronics
Music Electronics General discussion about music electronics
Old 10-27-2009, 10:27 PM   #1
Supporting Member
belwar's Avatar
Looking for an alternative to TAB1043 IC
Here is the datasheet
http://62.231.140.52/tnThumbnails/Da...DSA-112013.jpg
Can anyone suggest a drop in replacement for this? Im looking for something very low noise.. Any ideas? I can buy some old ones off E-bay, but i'd like to find a new one
bel
belwar is offline   Reply With Quote
Old 10-28-2009, 01:51 AM   #2
Don't know, what is it used in and what does it do there?
__________________
Old 10-28-2009, 04:58 AM   #3
Supporting Member
belwar's Avatar
Is an opamap in a bass pre-amp
Old 10-28-2009, 10:17 PM   #4
Quote:
I could barely make out on the datasheet that it is a "quad programmable" opamp.
I doubt that it is pin for pin swappable with any other part. What brand bass is it used in?
52 Bill is offline   Reply With Quote
Old 10-28-2009, 11:56 PM   #5
Quote:
Wal.
Obsolete since the early eighties.
Not pin compatible to any other quad opamp I know of.
You could use a TL064/074, but it would involve some serious surgery.
Cheers,
Albert
Albert Kreuzer is offline   Reply With Quote
Old 10-29-2009, 01:24 AM   #6
Supporting Member
Steve Conner's Avatar
Is that "programmable" as in, it has a bias pin that you can load with a resistor to set the internal bias currents? These used to be popular in battery-powered equipment (like active basses?) because you could set them to a low current for longer battery life.
Nowadays, you'd use a low-current op-amp like the TLC27L4. Or a regular low-noise one like the MC3307x if you're more worried about performance than battery life. The programmable op-amps would have had lousy performance (GBW, distortion, output drive capability) when running at low current. If you're looking for an upgrade, try keeping the same chip and turning the current up!
Or is it programmable as in an OTA? These are used to make voltage-controlled filters, and I heard the Wal basses had filters. The LM13700 is about the only OTA that anyone still makes.
__________________
"Transformerless is the way to go", said he, without a hint of irony.
Steve Conner is offline   Reply With Quote
Old 10-29-2009, 09:53 AM   #7
Quote:
Yes.
Here is a better data sheet:
Old 10-29-2009, 08:52 PM   #8
Supporting Member
Thanks Albert. This does indeed look like a disaster area of an op-amp, especially in the low-power mode. Whenever you see "performance similar to the 741" in a datasheet, you know it's time to run screaming. Almost any modern op-amp would be an upgrade.
Unless the circuit is designed around the crappiness. For instance, I notice the GBW is 50kHz in low-power mode! If it were a car, that would be 0 to 60 in 2 weeks. It might be that if you swap in an amp with more GBW, it would become unstable. Or maybe the poor GBW causes distortion that fattens the tone of the bass.
I'd still recommend investigating the bias set resistors on pins 8 and 16, with a view to finding out what current the amp is running at, and beefing it up if it's in low-power mode. This will make it run more like a modern op-amp would, and you can see how that affects your tone.
__________________
Tolex Alternative a1terrier Cabinetry 4 07-04-2009 09:24 AM
Alternative for PE? Shepherd Pickup Makers 12 05-04-2009 07:33 PM
Carbon Fiber as an alternative to wood for cabs? Cobra Cabinetry 17 01-19-2009 02:09 PM
komboking alternative? gdgross Theory & Design 1 04-14-2008 09:25 PM
Alternative To Forbon Phil m Pickup Makers 42 07-06-2007 10:46 PM
