Old 10-28-2009, 10:32 AM   #1
Marshall JCM 900 4100 Fading
Our 4100 started fading while we were playing the other night - the volume would drop unexpectedly to a fraction of normal and it wouldn't recover. We'd switch the standby off and wait half a minute and then it would be OK for a few minutes and then fade again and be very soft.
Is this a common problem with tube amps? Should we just replace all tubes or do we need a proper service. We have technical expertise in electronics but it's hard to fix a problem which is sporadic and you can't reproduce it in the lab...
cawoodm is offline   Reply With Quote
Old 10-28-2009, 03:44 PM   #2
mac1amps's Avatar
Since you describe the sound as "fading", I would suspect a faulty heater connection somewhere. Is this "common"? Well, with respect to connections being faulty in general, my pro-opinion would be yes (especially with respect to P.C. board connections). With respect to "heater" connections specifically (which, BTW are not P.C. board connections in this case), I would say not as much.......It's very typical to want to replace tubes first off, but I'd say it's more likely that re soldering will be needed somewhere.
__________________
Mac/Amps
"preserving the classics"
Berwyn (Chicago), Il., USA
(708) 484-8338
www.mac4amps.com
mac1amps is offline   Reply With Quote
Old 10-28-2009, 04:21 PM   #3
JerryP's Avatar
Dity effects loop jacks would be my first guess. Power tubes would be my second guess.
Jerry
__________________
FJA Mods
FJA YouTube
FJA Myspace
JerryP is offline   Reply With Quote
Old 10-28-2009, 05:03 PM   #4
Quote:
Jerry
Do you mean the Send/Receive out/in jacks?
Old 10-28-2009, 05:48 PM   #5
JerryP's Avatar
Quote:
Yes, they can cause a break in the signal path if they are dirty. You can plug a jumper cable in the loop to rule out the jacks. A quick shot of contact cleaner and plugging a cable in and out a few times usually cleans them up if they are the problem.
Jerry
__________________
FJA Mods
FJA YouTube
FJA Myspace
Marshall JCM 900 4100 jmcgeorge Music Electronics 5 08-28-2009 11:47 PM
JCM 900-4100 preamp question stratrat_57 Maintenance, Troubleshooting & Repair 13 07-11-2009 12:01 AM
Jcm 900 4100 How Can I Eliminate My Preamp ALEXZANDEREPAIR Mods & Tweeks 1 04-04-2008 06:40 PM
Marshall Jcm 900 4100 Repair In Chicago ALEXZANDEREPAIR Maintenance, Troubleshooting & Repair 2 03-12-2008 03:33 AM
jcm 900 4100 help!!!!!!!! ALEXZANDEREPAIR Repair and Restoration 5 10-24-2006 12:17 AM
