| | #1 |
| Member Join Date: Oct 2006 Location: Portland, OR
| Single tone knob question
Hey all, So, I've given the typical Brown Deluxe tone knob setup a chance, but I find that for the most part it seems to impart a honky tone (think the letter "R") to the channel, and I'm wondering if there's an appreciable difference between the 6G3 and 5E3 single tone knob setup. Or, perhaps there is a more versatile single tone knob wiring? I'm mostly looking to add and subtract upper mids instead of the more growly, lower midrange. Any suggestions? Or, perhaps this "R" tonality is just part of the Brown Deluxe vibe...but I fail to see on the schematic why this would present itself....or is it just a result of there being no typical TMB tone stack between the triodes??? |
| | #2 |
| Supporting Member Join Date: Feb 2007 Location: Wellington NZ
__________________ Building a better world (one tube amp at a time) |
| | #3 |
| Supporting Member Join Date: Jun 2008 Location: Italy
I would also give the "EH Big Muff Pi" tone control a try, very versatile for a "single knob" tone control, as it can also create a sort of "mid scooped" tone. Hope this helps Best regards bob
__________________ Foolproof equipment is hard to design, because fools are VERY ingenious... |
| | #4 |
| Senior Member Join Date: Mar 2008 Location: Germany
I've given my brown Deluxes normal channel a mid scoop filter. I replaced the .02 coupling cap (at the first triodes plate) with a .1 cap and a 120k resistor in series. The resistor is bypassed by a 150pF cap. This gives me a tone in between blackface and brown Deluxe. I like it. That way you might lose that honky "R". And it's undone very easy if you don't like it. Doesn't make the tone control more versatile, though.
| | #5 |
| Member Join Date: Jan 2009 Location: roanoke, va
dehughes, if your feeling adventurous, try this out. it's similar to the big muff control only with usable ranges from open to closed. c2 and r6 keep low and high frequencies from dropping off to no man's land. i love it. i can dial in almost any sound i want from it. just keep in mind that it was designed around my circuit so some values will change if you use a bypass cap on v1 for instance. that's just one example. your preamp configuration may be completely different from mine.
| | #6 |
The classic Fender Tone control has a reiprocal action. In one direction it bleeds treble, while in the other it provides a variable degree of treble bypass across the Volume pot. Naturally, like any Volume pot treble bypass, the treble boosting effect of that cap is most evident at lower volumes, and disappears as the volume level is increased. Of course, the big difference between guitars and guitar amps is that one is likely to leave the volume up full on the guitar (such that the bypass cap "fixes" things when you turn down below that), and more likely to have the volume at less than full on the amp. That bypass cap essentially duplicates the role that a "bright" switch fills, and the thoughtful reader will note that there are simply no Fender amps that use a single Tone pot yet also have a "bright" switch. More recently, I was thinking about the tone control on my guitar, and realized that while I liked the reciprocal tone control on my tweed Princeton, it could be made more flexible. I tried out an experiment and it worked. You can read about it here: A novel kind of guitar Tone control I see no reason why the same principle could not be productively applied to a guitar amp tone control, albeit with changes to component values. I may well give it a whirl on my Princeton too. |
| | #7 |
| Senior Member |
I'm a big fan of the old gibson style single control. It gives scooped mids in the middle positions and treble or bass rolloff at the extremes with a nice smooth slope. At the front end of a cranked up amp it has a neat effect on distortion character, at the front of a cleaner amp it serves well to produce useful clean tones of different kinds (top boost, blackface mid scoop or jazzy treble rolloff). here's a gibson amp with the circuit: http://schematicheaven.com/gibsonamps/ga30rvt.pdf I think you'll find it works better driven from the plate of a triode. There are modern amps that seem to support this theory. jamie |
| | #8 |
| Senior Member |
I thought I'd add- it's pretty low loss- only around 6 to 8 dB at the bass side and less on the treble end. You can reduce the loss and improve the action a bit by using a 500k or 1M pot. The mid scoop is down 15 to 25 dB depending on position. Here's a plot: ![]() jamie |
| | #9 | |
| Junior Member Join Date: Jun 2009
| Quote:
| | #10 |
| Senior Member |
Yeah, that's what I prefer too- just the mid control from the 30rvt. The plot I posted was that control with a 500k pot instead of the 250k in the original schematic. You can easily scale it to make it work a little better with higher plate loads like a pentode. I think it works well with a phase inverter and power section that's breaking up just a little bit. The cut control can serve to take the edge off of things- really a great combo for natural sounding low gain amp distortion tones. Not so much gain that it doesn't work with a few pedals out front...but enough to make it obvious that it's not 100% clean and add some interesting harmonic content. jamie |
| | #11 | |
| Quote:
| | #12 |
| Senior Member |
5spice- google it. I just found it the other week. I'll send you a few of my own simulations to get you started. jamie |
| | #13 |
Wow. GREAT info, all. Thanks so much. I'll get my soldering iron out and see what happens... I'll start with trying the Gibson Mid/Matchless Chieftan Mid pot thing and see if that does it (I have a Cut control already wired in, which is supposed to make a good pairing). If that doesn't do it, then I'll give the Carmen Ghia tone wiring a try. After that, I'll give Steven Delft's Moonlight tone control a try. If that still doesn't do it, then I'll try your idea, txstrat, and try some sort of filter setup to drop some mids. |
| | #14 |
| Senior Member |
this gibson 30rvt thing is the carman ghia tone circuit. I really like Dr Z amps and I'm torn between outright copying his ideas and knowing that most of his designs are really great ways of implementing old ideas. I've lived in Nashville for the last 12 years and it's hard to miss how many great Z amps are in Nashville. They work and sound great in the real world of clubs and churches where Marshalls and Mesa don't do the trick. Of course...that makes them great in the studio too. jamie |
| | #15 |
| Huh. I have a "Phoenix" layout (a copy of the Carmen Ghia, I assume) and it is wired a bit differently than the Matchless Chieftan and Gibson 30RVT in that all three lugs are used in the Carmen Ghia, whereas only two are used in the Chieftan and 30RVT. Perhaps I have an incorrect schematic...
| | #16 |
| Senior Member |
You're so right! I played an old gibsons and looked at some schematics and simulated it the way it's hooked up in the Dr Z amps- so you're right, it's not the same critter. I apologize to anyone who read my bad info and to Dr. Z! I need to give credit where credit is due! Wired in like the gibson circuit gives the high pass effect but no low pass. Connecting the control Dr. Z style gives treble rolloff at the extreme. jamie |
| | #17 |
So, I tried the Gibson/Matchless wiring for my tone knob, and it sounded...well...like a really good midrange pot should. I then wired it up like the Carmen Ghia, and liked that much better. A wide sweep of tonal options... Next up I might try the Moonlight tone pot wiring, but I'm inclined to give this Carman Ghia wiring a thorough shot first, as it seems okay. In case you're wondering, the amp I'm working on started off as a Brown Deluxe-ish project and now is setup as following: - Parallel channels, one 6SN7 (triodes in parallel, single volume knob only), the other a 12AX7 triode (volume and tone), summed into the other 12AX7 triode a la the 6G3 schematic - Long tailed PI with switchable feedback loop - Cut control - Cathode biased 6V6 pair - 5AR4 rectified The problem I'm having is that the two channels are effecting each other in that whatever I do to the 12AX7 side changes the tonality of the 6SN7 side. This is what I was hoping for to a certain degree, but it's far more complicated than I expected due to the two channels' interactions. I thought they'd be more separate and only would be blended when the volumes were up, but I'm finding that the 12AX7 side's tone pot wiring and setting changes the vibe and tone of the 6SN7 side, even when the 12AX7 side's volume is turned completely off. Thus I'm always having to find the happy compromise when I change one thing on either channel...which makes finding the "right" thing much harder... |
| | #18 | |
| Quote:
| | #19 |
| Senior Member |
It seems to shift the whole control up or down slightly- looking at the simulation plot I don't know that the difference would even be audible between 500k and 1M at most positions. I think the 500k makes the knob a little more responsive and shifts the response up about a quarter octave at a given position. 250k does the same but a little more extreme, with a slight loss across the range. I'd say try tacking large value resistors across the outer lugs of the pot and see if it makes a positive difference. I don't know that I'd bother swapping the pot if it wasn't easy to get to and I had another one just laying around. I'm confused- are the channels summed using 220k resistors like the 6g3? I would have thought that would have removed a lot of the interactivity of the controls. Are they summed before the second ax7 triode or after? jamie |
| | #20 |
Okay. Thanks. I swapped in a 500k and it didn't make that much of a difference. I do like this Carmen Ghia setup, but it is a bit tooooo scooped and bass heavy, especially with the Brown Deluxe values all around it. I'll give the Moonlight tone setup a try next...then possibly one of the Big Muff variants. The bummer with this amp is that I can't seem to get the inherent tonality straight. In changing the 12AX7 side I seem to be changing the 6SN7 as well. I have the two channels summed via two 220k resistors before the other 12AX7 triode (a la 6G3), which solved my problem I was having before when I had both channels summed at the PI input (was getting a closed down tone on the 12AX7 due to running a 500pf cap across the summing resistor for the 6SN7 channel when summed at the PI). Running both 6SN7 triodes in parallel and summing them into the other 12AX7 triode solved that issue, but I still seem to be getting harshness from the 12AX7 side....much like what one would expect if they bypassed a TMB tone stack (r.e., high, harsh, gainy midrange). Granted, cranking the 12AX7 side made the amp sound killer (mini-Marshall), but I figured I could tinker a bit and get the 12AX7 side more versatile for non-cranked tones as well. Oh well, the life of an incessant tinkerer.... |
| | #21 |
Hi de hughes Remember that the answer is not all in the tone stack. Picking up on your remark about the scoopiness being too scooped, if you want to lift some bass out of the whole circuit use a smaller cathode bypass cap and/or coupling cap at v1. For example if you have 25uF ck in there now try 2.2uF, this has a subtle effect of taking out boominess throughout the whole amp, including how the bass responds in the tone control(s)
| | #22 |
OKAY, now we're getting close... I wired up the "Moonlight" tone stack and it seems to sit nicely as a "mellower" Brown Deluxe tone stack.....that is, it takes the edge off of the midrange harshness found in the typical 6G3 tone wiring. However, I think I'd like a bit more "air" on the top. How would I go about opening up the top end a bit on the Moonlight tone setup? Bright cap bypassing a resistor somewhere? |
| | #23 | |
| Quote:
__________________ Building a better world (one tube amp at a time) | |
| | #24 | |
| Quote:
The reason I think the 12AX7 side is in balance save for the tone pot sweep is that with each iteration of tone pot wiring I've found the 12AX7 side to do it's thing to whatever degree the tone wiring would allow. That is, it sounds and feels like a Brown Deluxe that's being put through various filters (which in reality, is exactly what's going on). I'm finding that certain tone setups are better than others, AND that the underlying tonality seems to be good....just that certain setups bring out this tonality in more versatile, pleasing ways than others. So, I'm confident in the voltages, caps, and resistors around the stage(s) themselves, but I'm not yet settled on a tone pot wiring that brings the most out of the circuit. Who knows, maybe I'll come full circle back to the Brown Deluxe wiring......(I hope not...) | |
| | #25 | |
| Junior Member Join Date: Nov 2009
| Quote:
| | #26 | |
| Quote:
As for putting caps across the cathode of a gain stage...that's not a bad idea, but I do like the gain in the 6G3 circuit, just not the tone control of a 6G3 circuit. Hence my looking into alternate designs. Any particular recommendations for your tonestack in a 6G3 setup? There sure are a lot of lows and low mids to spare there....but that's part of the fun once it gets cranked. I'm hoping to keep the general, gainy, raucous vibe of the 6G3 there, albeit with the ability to clear it up a bit with a twist of the tone knob. | |
| | #27 |
I have tried the Gibson GA30 tone knob and I feel it's too scooped, even with substitutions. Look at the Matchless Chieften mid control. It's very similar to the GA30 one but wired up a little different. The big difference is it doesn't sccop the tone nearly as much. use different resistors and/or cap to adjust the scoop depth and position. Thanks to imaradiostar for all the help with Spice. |
| | #28 | |
| Quote:
| | #29 | |
| Senior Member | Quote:
Have you tried a different 12ax7? I forget- using a bright cap across the volume? Maybe add a conjunctive filter like the bright chan of a marshall plexi or the reverb blend circuit from a blackface fender? jamie | |
| | #30 | |
| Quote:
Different 12AX7s...yup, no real change. Bright cap across the volume...good idea! Conjunctive filter...please explain...or post examples, as I'm still not getting it when I'm looking at schematics. I see bright caps on top of mixing resistors....but wouldn't that bleed highs from the other channel? | |
| | #31 | |
| Quote:
When you model the GA30 / cheiften control, try 100k's, there's a little less scoop and shifts it so there's a little more lower mids. may sounds cool, especially if you don't want to loose too much gain. | |
| | #32 | |
| Quote:
| | #33 |
| Senior Member |
My suggestion would be to replace the 250pf cap with a 500pf- it'll make the mid scoop less pronounced and increase the relative amount of treble in relationship to the bass. The perceived overall effect may be darker though with the increased mids. Maybe a conjunctive filter isn't the correct term for it but I'm thinking of a voltage divider with a cap across the top resistor- much the same as a volume with a bright cap. The two channels on a four input marshall are blended with 470k or 270k resistors. The lead channel generally has a 250pf or 500pf cap across it- you could try something like that with your bright cap. A circuit like that is easier to design if there is a fixed resistor as the path to ground. A great example would be the blackface fender verb blend circuit. It creates a hi frequency shelf that lends a lot of that fender sparkle...and makes them sound harsh with fuzz pedals. jamie |
| | #34 |
Okay, that makes sense. I actually had a 500pf in there at first, as I was transitioning over from another tone wiring. I liked the 500pf better, IIRC, but took it all apart to try the Moonlight tone wiring. I'll give the Big Muff tone knob a try next and see how that goes. Actually, I'll try Yunger's variation on it first and see what I think of that. Then I'll give Txstrat's idea a shot. After that, I'll start making my own tone stack. |
| | #35 |
| Senior Member |
The Big Muff tone circuit (unless scaled) really works best with low impedance drive and a buffer after it. Have any mosfets laying around? jamie |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| AC15CCI + tone cut knob question. | petemoore | Mods & Tweeks | 1 | 03-02-2009 08:19 PM |
| Filmosound - Tone Knob - Tertiaries | atmars | Conversions | 14 | 11-07-2008 02:52 AM |
| Tone Knob | eidlyn | Guitar Tech | 15 | 10-13-2008 02:09 AM |
| Tone knob has no effect on tone. | srvprodigy | Guitar Tech | 3 | 09-07-2008 06:34 PM |
| Tone knob | bluefoxicy | 5 E 3 | 3 | 06-25-2008 07:51 AM |
