Go Back   Music Electronics Forum > Amplification > Guitar Amps > Theory & Design
Old 10-29-2009, 08:11 AM   #1
6X4 output voltage
Im currently building a 5f2 style amp utilizing a 6x4 rectifier tube. As for the wiring part, I have only gotten the power supply done and nothing else. I need some input from you guys to confirm that my voltage readings are on the right track. The two plates on the 6x4 read exactly 300VAC each. This is yielding 404VDC at the cathode and first filter cap/choke. Just to be sure, that does seem like a reasonable number under no load correcct?
EETStudent is offline   Reply With Quote
Old 10-29-2009, 03:10 PM   #2
voltage seems ok. I wouldn't use more than 10uf in the first stage of filtering. Best of luck with your project!
booj is offline   Reply With Quote
Old 10-29-2009, 04:15 PM   #3
Thank you booj. Yea I've got 8uF Sprague Atoms across the board. Im hoping that voltage will get knocked significantly under a load
Plate voltage is too low on output valves. phylomatic Maintenance, Troubleshooting & Repair 17 03-25-2009 11:59 AM
Output tubes' current or negative voltage? Le Basseur Theory & Design 4 05-23-2008 08:31 AM
2 x 6AQ5 pushpull with 6X4 rectifier question Pedro Vecino Theory & Design 3 05-23-2008 01:31 AM
trying not to exceed 6X4 ratings EETStudent Theory & Design 6 05-16-2008 07:53 PM
PI output swing voltage ? petemoore Theory & Design 2 02-17-2008 07:04 PM
