Go Back   Music Electronics Forum > Amplification > Guitar Amps > Theory & Design
Old 10-30-2009, 05:31 AM   #1
5e3/AC15 mod
Tubenit's schematic in this thread got me thinking of a mod I'd like to attempt to my recent 5e3 clone build.
I've split the cathode bias of the input tube sections so that each channel has a completely different voicing. But, now I'm thinking of adding another preamp tube into the circuit so that one channel can have the tradition two gain stages befor the PI, and the other channel three gain stages along with a cathode follower pushing the tone stack. Along with a master volume just prior to the PI (the volume pots just behind the first gain stage become gain controls). I have a pair of Yellow Jackets so I'll build it for 6v6/6L6's with the ability to run el84's easily.
Here's my mod'd 5e3 schematic stealing pieces from Tubenit's reference. What-cha think? Worth the effort?
afm_380 is offline   Reply With Quote
Old 10-30-2009, 05:56 AM   #2
I'm leary of the Yellow Jackets ability to match EL84's up to a 6L6 type output tranny. I tried a pair on the output of a Peavey 100 series Classic 50 watt combo, and got 10 watts and all the crossover distortion I could hope for. (bad mismatch)
booj is offline   Reply With Quote
Old 10-30-2009, 07:11 PM   #3
IMO, I think your VOX channel is going to have way too much gain and mush out pretty quickly. The 5E3 channel has alot of gain as is but the VOX one you have 3 gain stages and a cathode follower with no attenuation.
HBamps is offline   Reply With Quote
Old 10-30-2009, 07:44 PM   #4
If I have enough realestate I may add a second pair of power tube sockets for the el84's ... gotta do some more chassis design work for that.
I can lose a gain stage by turning v3 into a longtail phase inverter, but then my tweed channel would only have one gain stage (I wonder how that will sound ... ;o).
Thanks for the suggestions ... this new obsession with tube amp design is AWESOME.
Old 10-30-2009, 08:30 PM   #5
you could experiment with the VOX side and try it with or without V2a.
Old 10-30-2009, 11:31 PM   #6
Supporting Member
FWIW the 5G9 has a LTP straight after the VA input stage and has a typical tweed vol-vol-tone stack in between. It makes about 12W and sounds gr8 with a 20W greenback if you use 2.2uF on the first cathode bypass cap and .047uf as the first coupling cap. (So that's an idea for your tweed channel)
__________________
Wiring up 5E3 / AC15 combination. Help wanted. platonicbomb Guitar Amps 15 02-22-2009 01:15 AM
5E3 Power Mod Mikeb 5 E 3 6 02-23-2007 06:20 PM
5E3 Gain mod questions leucein Mods & Tweeks 0 01-06-2007 06:29 AM
choke mod for 5e3 martin 5 E 3 5 12-19-2006 01:03 AM
Mod to basic AC15 circuit mdisanto Theory & Design 3 11-30-2006 01:06 AM
