Old 10-30-2009, 08:54 PM   #1
JC@
JC@'s Avatar
fender amp problem
hi
I'm having a problem with a fender clone, but a twin reverb schem is ok to illustrate it.
I get ugly distortion, and I tracked it to pin 2 for a grid of the PI tube. The signal shows distorted and flattened on the lower side of the wave.
I get correct dc on both plates but with .5 AC on them
Feedback lifted and the problems persists
Well, help me please
JC@ is offline   Reply With Quote
Old 10-30-2009, 09:21 PM   #2
mmm
check every resistor value from the PI with a multimeter
change the electrolitic cathode bypass caps.
check that there is no soldering touching the chassis underneath the board.
i will replace those 0,1 uf poly-film or (chocolate drop) caps (that goes from the PI tube to the output tubes) because they might have DC leakage on them
But go simple first like changing pre-amp tubes, checking voltages according to the schematic.
u might have ultrasonic parasitic oscilation on the pre-amp , that cuts lots of headroom in the output stage making it to sound like a "broken speaker" without having a broken speaker
Lee_ranaldo is offline   Reply With Quote
Old 10-31-2009, 08:26 AM   #3
melvin's Avatar
one side of the wave being 'flattened' does not seem terribly unusual. Does the output of the previous stage have the same form?
did you mean .5V on the plates of the PI with no signal input? If so, what does that look like?
And what does the amp sound like?
melvin is offline   Reply With Quote
Fender Transformer Problem MstrB Maintenance, Troubleshooting & Repair 4 10-29-2009 10:34 AM
Fender Amp Power On/Off Light Problem ric36012 Maintenance, Troubleshooting & Repair 2 07-31-2008 04:30 AM
Fender Stage 160 amp problem F100390 Maintenance, Troubleshooting & Repair 14 02-09-2008 08:19 AM
fender pro 185 sold state amp problem amptech Music Electronics 4 12-15-2007 12:53 AM
Fender Twin amp problem... ubernerdsteve Maintenance, Troubleshooting & Repair 5 09-04-2007 02:13 PM
