Go Back   Music Electronics Forum > Amplification > Guitar Amps > Build Your Amp > Tweed Builders > 5 E 3
Old 10-31-2009, 04:27 AM   #1
Fuse rate to use 5E3 in EU
Hi all,
I'll back to Europe with my tweed in 2 days. I was advised that I should
change the fuse type from 2a 250V to 1a 250V, what would be more
appropriate "slow blow" or "fast blow"?
Thanks
tweed is offline   Reply With Quote
Old 10-31-2009, 05:41 AM   #2
Supporting Member
multiply volts with amperes (for each winding) and you get VA. Sum up the VA values and you get the whole VA of the secondaries. Divide that by the mains voltage and you get the primary amperage. Take the nearest value and multiply by two.
For instance
PT:
650v x 70ma = 45.5va
6.3v x 2a = 12.6va
5V x 2a = 10va
68.1 va altogether
68.1va / 240v = 0.29a
Match to .25A and multiply by two = 0.5A mains fuse.
Somebody's bound to correct me if I'm wrong
__________________
Old 10-31-2009, 09:45 AM   #3
Tweed,
does your amp have a voltage selector? Set it for 230V (or 240).
2A x 115V = 230VA
1A x 230V = 230VA
So 1A is what you need.
If you are using a stepdown transformer, leave the original 2A fuse in there.
Tubeswell, your calculations are correct, but a cranked amp could draw more than 140mA on the B+ and take out a .5A fuse.
Slow blow fuses for all tube amp mains.
Cheers,
Albert
Albert Kreuzer is offline   Reply With Quote
Old 10-31-2009, 02:37 PM   #4
The VAC is 220V and my power transformer primary has 220, 230, 240v taps.
So, 1A 250V slow blow will be fine.
I thought that fast acting would be better, but I understand they may be to sensitive.
Tks guys
Small Stone Nano, Rate RabbitChaser Guitar Effects 3 10-28-2008 07:39 PM
Novice 5e3 Build Pops fuse & has low hum/no output Apocrathia 5 E 3 25 06-13-2008 09:00 PM
5E3 immediately blows fuse bk121 5 E 3 13 02-16-2008 07:17 PM
5E3 Fuse ?'s cooper 5 E 3 3 11-29-2007 01:47 PM
(EU) Deichton Guitar Cabs johanare Lobby 0 11-03-2007 05:39 PM
