Results 1 to 8 of 8
Thread: Crate V-100h Head Died
    Oct 2009
    Georgia
    4
    Exclamation Crate V-100h Head Died
    The other day I was practicing at home and in the middle of a song my amp just died. Now no power reaches the tubes or anything. The power light doesnt come on but the fan does. It rocks back and forth and sounds like a clicking noise. I unplugged a 2 wire connection from the circuit board and and the fan runs but nothing else happens and the clicking sound is still there. I plug it back in and the fan rocks back and forth. All the fuses are good. Ive tried it on different outlets etc. and there are no bad solder joints or nothing is burnt or smells burnt. any ideas? I do have the schematics if that would be helpful.
    Dec 2008
    Wernersville, PA
    5,369
    Crate schematic
    Can you post the schematic?
    Oct 2009
    Georgia
    4
    Quote Originally Posted by Jazz P Bass View Post
    v100h-schematic-pg-1.pdf
    v100h-schematic-pg2.pdf
    0027747-00-reva00-sch.pdf
    0028168-00-reva00-sch-2-.pdf
    v100h-tube-location.pdf
    v100h-vii-bias.pdf
    That should be everything. Thats everything I have. I do have the manual too here it is...
    V-100H Manual.pdf
    Dec 2008
    Wernersville, PA
    5,369
    SMPS
    ZMan
    Hey. Good luck with this one.
    The power supply is a switchmode.
    This is the future.
    QSC PLX older amps have a kit to fix there switchers.
    That is another rant, the output section goes & it blows up the power supply.
    Thanks QSC. Job security.
    Anyway, I would take this puppy to a reputable tech who understands swichmode power supplies.
    Senior Member Enzo's Avatar
    Lansing, Michigan, USA
    18,021
    That amp uses a switching power supply - it rectifies the mains directly. Unless you know what you are doing, these are EXTREMELY dangerous to work on. The voltages in a tube amp can KILL YOU as it is, but these switching supplies are extra hazardous.
    The pulsing fan and ticking noise is your switching supply trying to start up. Either the supply itself has failed, or something in the amp circuits - a power tube most likely - has failed and the switcher is protecting itself by instantly shutting down after it starts and finds excess load.
    technically, the first step is to pull the connectors off the right side of the power supply and hte loose wires there, noting where all go, and power on to see if the voltages are coming out of the switcher. This is done with a volt meter.
    If the switcher is dead, than I start looking for rectifiers on the secondary.
    Oct 2009
    Georgia
    4
    Ok I'll quit tinkering with it then and save it for a professional. Should I trust it with the guitar techs around here in Augusta, GA or take it to a certified one in Atlanta, GA?
  7. #7
    18,021
    A competent technician is a competent technician. I don;t know which ones live where. A Crate authorized shop may be more familiar with this model and ones like it. I have been working with switching supplies for decades, but not all amp guys have. The safety concerns me, the switcher itself may be just fine.... or not, but you need to know what you are looking at.
  8. #8
    Oct 2009
    Georgia
    4
    Thanks I'll call around.
  1. modding a crate stealth 50 watt head.
    By Heurkins91 in forum Mods & Tweeks
    Last Post: 10-13-2009, 08:32 PM
  2. Marshall Tsl 100h Problem
    By Sarah BAT in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-28-2009, 08:30 AM
  3. Crate head gx2200h channel problems
    By kain2k in forum Maintenance, Troubleshooting & Repair
    Last Post: 06-01-2009, 03:46 AM
  4. need a schematic for an ibanez tb 100h
    By Gunn_Slinger in forum Schematic Requests
    Last Post: 02-12-2009, 05:42 PM
  5. Noisy Crate PA head
    By Chulio in forum Music Electronics
    Last Post: 01-09-2008, 12:35 AM
