Which Twin amp do you have?
I have schematic for The Pro.
The wattage switch applies different voltages to B+ (output tube plate voltage for one)
Higher wattage setting, higher B+ voltage.
So yeah your bias reading will be higher for the higher B+.
Set the bias for your highest wattage setting.
Tremelo MUST be OFF.
The Pro amp calls for 60ma's per side.
LinkBack URL
About LinkBacks
