| | #1 |
| Member Join Date: May 2008 Location: minnesota
| 4 7591 power tubes...
I have 2 amps that both use a pair of 7591 power tubes with various preamp tubes. I was wondering if there were any amps that have been made that use 4 7591 power tubes. I looked and all I found was some old fisher hi-fi stereos that used them. I really like the sound of the 7591 tube, as opposed to a 6L6 quad, or an EL84 quad. But the amps that I have found that use 7591's seem to put out at most, like 30 watts, and I really would like to have like 50+ watts. Is there something inherent about the 7591 tube that disallows it to be used in a quad? what's up with that? |
| | #2 |
| Senior Member Join Date: Dec 2008 Location: Wernersville, PA
| Parallel tubes
I would not think the tube itself would care how many you use in parallel The circuit itself would. |
| | #3 |
| Senior Member Join Date: Jun 2006 Location: California, USA
There is nothing inherent about the 7591 tube that disallows it to be used in a quad. It is just from an era where the designer would change to another tube type if power output in the 50 watt region was desired.
| | #4 | |
| Member Join Date: Apr 2009
| Quote:
| | #5 | |
| Quote:
Hammond use them in a few of their later designs. | |
| | #6 |
| 7591 heaven
I have two pairs of these 7591 tubes in my Fisher 800-B. I think it is a synergy thing. Fisher- 7591. This amp sounds |
| | #7 | |
| Member Join Date: Apr 2007
| Quote:
![]() The power output of tubes is a function of the ability of tube to handle voltage on its plate and current. Link to the Tube Data Sheet for the 7591A: http://www.tubezone.net/pdf/7591.pdf The tube was very popular in the mid-60s because of increased power handling / cleaner tone v. 6V6s; Ampeg, Gibson, Guild, Audio Guild ... many others made 7591 amps ... usually 25-30 watts for push/pull twins. I don't know of any other quad 7591 designs. CJ | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| #42 power tubes? | distorto | Conversions | 2 | 08-17-2009 07:43 AM |
| Noisy power tubes | Prairie Dawg | Tubes (Valves) | 2 | 04-30-2009 05:07 AM |
| JJ-7591 Special Considerations? | Tiago | Theory & Design | 20 | 04-30-2008 05:08 AM |
| Which power tubes to use? | Lizard King | Build Your Amp | 1 | 01-13-2008 05:55 AM |
| Ampeg rewire 7591 to accept 6L6's | tuberattler | Mods & Tweeks | 12 | 10-10-2007 06:58 AM |
