Go Back   Music Electronics Forum > Amplification > Guitar Amps > Build Your Amp
Old 11-02-2009, 01:14 AM   #1
SE 6l6 build circuit recommendations
I'm looking for circuit recommendations using mostly parts I have on hand from this donor chassis - has PT, SE OPT, 5Y3, 6l6, a couple 12AX7s. I have a misc collection of other driver tubes but would like to stay with the 6L6 output.
I've built a fender champ clone and a fender deluxe clone in the past so I have that experience behind me. I'm looking for a circuit that's fairly simple but generally well regarded.
Ideas?
cubby01 is offline   Reply With Quote
Old 11-02-2009, 10:37 AM   #2
5F2A is a bit more flexible than a tweed champ, use a 10W cathode resistor at 6L6 pin 8, use a 100v rated cathode bypass cap. Try a slightly smaller dropping resistor between B+ & screen nodes (2.7K to 4.7K?).
MWJB is offline   Reply With Quote
The Following User Says Thank You to MWJB For This Useful Post:
cubby01 (11-02-2009)
Old 11-02-2009, 08:30 PM   #3
Thanks, that's one I will look into. Anyone have others?
SE 6L6 Harp Amp Design stingray_65 Theory & Design 3 09-18-2009 09:18 PM
Small SE 6L6/KT66? EFK Guitar Amps 8 08-17-2009 08:28 PM
First cabinet build - recommendations, plans, pictures... trumpus Cabinetry 9 04-10-2008 04:05 PM
Reverb circuit -- any recommendations? Wrnchbndr Guitar Effects 1 02-06-2008 06:24 PM
6L6 SE Amp with 20 Watts? rexindigo Guitar Amps 36 12-03-2007 11:17 AM
