Old 11-02-2009, 08:51 PM   #1
JT3
Some info. On Line 6 AX2?
I have a couple of these. One's a beater and the other I use on gigs. I put V-30s in it, worked the patches for weeks, and have some killer tones. An under rated amp in my opinion. It's the tweaking that's really important.
Here's my issue. My bite and sustain are losing it. I use to be able to control sustain and feedback pretty nicely but it's not there any more. Some of the patches, even though they haven't changed, are losing their initial attack or bite. The clean patches seem OK.
Any suggestions on what may be going on?
Thanks for your input.
JT3 is offline   Reply With Quote
Old 11-03-2009, 03:06 PM   #2
Jazz P Bass's Avatar
AX-2 Digital amp
Please keep in mind that this is a digital amp.
A computer with a speaker.
Seeing that it is what, 10 years since it was manufactured, I would look real hard at the power supply.
You need a dead solid DC supply with very little AC ripple.
Jazz P Bass is offline   Reply With Quote
Old 11-03-2009, 03:30 PM   #3
JT3
I have a Furman regulator/conditioner on it. Supply is not a problem. I appreciate your input.
Old 11-03-2009, 04:44 PM   #4
Your Furman only conditions the ac line power going into the amp. Jazz P was referring to the ac to DC power supply inside the amp. You can have the nicest ac voltage possible going into your amp, but the amp itself runs off DC voltages generated by the internal power supply. That is what he's suggesting you have checked.
__________________
ST in Phoenix
Phostenix is offline   Reply With Quote
Old 11-03-2009, 07:53 PM   #5
Line 6
Yeah, what Phostenix said.
Sorry for the unclear thought.
If this amp was on my bench, that is the first thing that I would look at.
Cheers.
Old 11-03-2009, 09:20 PM   #6
JT3
Thanks guys, it's much appreciated. Anywhere you know of that I can get the specs?
Does anyone have info on how to build a LINE 6 FB4 FOOT CONTROLLER olddawg Guitar Effects 1 02-06-2010 01:23 PM
Need schematic for Line 6 Ax2 terrykvan Schematic Requests 3 08-18-2009 03:44 AM
Line 6 AX2 Power Transformer Hookup Lordbovary Maintenance, Troubleshooting & Repair 5 08-12-2009 03:14 PM
Line-out vs Pre-out lowell Theory & Design 3 03-09-2008 10:13 AM
line 6- need help Mshredder Guitar Effects 3 08-13-2007 02:35 PM
