| | #1 |
| Senior Member Join Date: Jul 2009 Location: Phoenix, AZ
| Best High Current Connector
It seems that there are quite a few newer amps that have issues with connectors that can't handle the current going through them. This has got my wondering if there exists a type of connector that is superior for handling higher current connections or if one should always just use hard wired connections for high current wires. Any opinions or best practices that you follow?
__________________ ST in Phoenix |
| | #2 |
| Senior Member Join Date: Dec 2006 Location: York Pa
Specify "high current" and where it's used in an amp? Are you talking a string of KT-88s/EL-34s that'll pull 10A of heater current or a mains connection that'll see 5A or...? I made up some 2/0 ground straps for work today that will probably see 400A at peak; the cabling for our welding torch is easily 5/8" diameter. So high current is, well, relative, and so are the connections. I can only use eyelets and bolts for the stuff at work, anything else is suspect. Something tells me though that's not really the answer you're looking for.
__________________ -Mike |
| | #3 |
The problem is when they se a connector rated for 5A and decide to run 5A through it all day. I see aq red-line on my car tachometer too, but I don't see it as an invitation to drive all over with teh engine revved that high. One simple solution is higher current Molex pins. Most of these inline connectors are in the KK156 series. The little springy pin bears on one side of the male pin. Molex makes a type pin called the "trifurcon" pin. It is like the basic one, but has also little springy wings on the sides. SO it grips the male pin on three sides. A connector fill of those is substantially tighter to insert and remove, but they handle larger currents, or they handle the same currents with larger contact area. We used to have trouble with those Molex's burning up in another industry. Trifurcons solved the problem. I now use them to make cable ends in amps to solve similar burning molex problems.
| | #4 |
| Can you use the Trifurcon connectors with the existing male pins on the PCB, or do you change out the whole thing? Thanks, that's the kind of thing I was wondering about.
| | #5 |
The trifurcon pins fit in the same housings for use on the same male pins. The only difference is that they bear against the sides of the male pin as well as the one face the regular pins use. You can extract the normal pin from the female housing, crimp on a trifurcon in its place and shove it back into the hole. Trifurcon pin, not the extra little side flags. MOLEX - - 3.96mm (.156") Pitch KK® Crimp Terminal - 6838 / 7258 / 6438 Upper right, both regular and trifurcon pins for same KK156 housings. http://www.mouser.com/catalog/629/1178.pdf Here is more than you want to know about such connectors: Pinball: Molex Connectors and Terminal Pin Crimping Explained
| | #6 |
| Supporting Member Join Date: May 2006 Location: Glasgow, Scotland
There are also the 4-way connectors used for power on hard disks and CD drives (also made by Molex) and then a whole host of industrial connectors, all the way up to the 600 amp Anderson Powerpoles, which are used for things like jump starting trucks. I like to build tube amps on two chassis, the one with the tubes on it being rubber mounted to absorb shock and vibration. Last time, I used an ITT Trident connector to plug the two chassis together. This is a big badass thing with gold-plated pins rated at something like 13 amps. The Ninja-Deluxe
__________________ "Transformerless is the way to go", said he, without a hint of irony. |
| | #7 |
Bunch of old Seeburg juke boxes from the tube era had two large chassis in them, one was hte amplifier, the other the control unit. They plugged together to share power with mating large Jones plugs ![]() yeah, there are tons of high current connectors. I am not married to the trifurcons or anything, but when there is an existing Molex, they are a simple current upgrade.
| | #8 |
Thanks, guys! Good information.
| | #9 |
| Senior Member Join Date: Aug 2008 Location: Phoenix
Anderson Power Products "PowerPole" are great. I had a project that I was going to use them for that had separate control/power sections. I never built it though. Standard Powerpole Family |
| | #10 | ||
| Quote:
Quote:
__________________ ST in Phoenix | ||
| | #11 | |
| Quote:
| | #12 | ||
| Quote:
| | #13 |
Yeah, those little connectors by APP are a "wiping" type that clean themselves when cycled and are rated at 600v. I was going to build a combo with the Pre-amp and controls up top and have the PSU and P-P section on the bottom of the cab. Using a cable with connectors to mate them. I like the idea of having the weight on the bottom of a single speaker combo, just seems top heavy otherwise.
| | #14 |
| Senior Member Join Date: Mar 2007 Location: Philadelphia suburbs
I had this type on a foot pedal for a solid state amp I had while in college. I loved the amp (forget what it was) but hated the connector. As the amp aged the pins all became loose and had trouble aligning every time I tried to plug it in.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Concert head footswitch connector | Nyqusit5 | SUNN | 3 | 07-02-2009 06:09 PM |
| Wanted - High Power, High Voltage, Audio Frequency Transformer Manual | Kim | Tubes (Valves) | 16 | 06-04-2009 03:32 AM |
| High-Pitched Squealing at High Volumes | harry | Maintenance, Troubleshooting & Repair | 19 | 04-07-2009 10:44 AM |
| marshall VS265 - high pitched noised at high volumes | littlered | Maintenance, Troubleshooting & Repair | 1 | 02-23-2009 11:10 PM |
| Roland/Yamaha guitar synth 13-pin connector type? availability? | Corvus | Guitar Tech | 2 | 01-30-2009 01:23 PM |
