| | #1 |
| Member Join Date: Jan 2007 Location: Birmingham Alabama
| High B+ Voltage in Build - Can't Find Issue
I need help troubleshooting a build. It's a 6v6 power section, a When I fire it up I am getting high AC and DC voltages. Also my bias voltage is very low. I have swapped the PT tranny lines, retraced phase inverter wiring and double checked the bias filter to make sure positive was running to ground. I swapped the PT and the problem remained. I can't find an issue other than my voltages are way too high. I've used a harvested OT and am about to pull it and try an OT I know work. Before I do this does anyone hav any other suggestions? |
| | #2 | ||
| Supporting Member Join Date: Feb 2007 Location: Wellington NZ
| Quote:
Quote:
More information is needed about what you are trying to build. Can you please post a schematic? What are the AC voltages on your PT secondaries? What is your B+ DC voltage?
__________________ Building a better world (one tube amp at a time) | ||
| | #3 | |
| Member Join Date: Apr 2009
| Quote:
| The Following User Says Thank You to Prairie Dawg For This Useful Post: | jlatrace (11-04-2009) |
| | #4 |
| Old Timer Join Date: May 2007 Location: pacific north west
Sounds like a rectifier problem to me. The post title reads "High B+ Voltage in Build". Is this a new build then? Did it ever work correctly? Chuck |
| The Following User Says Thank You to Chuck H For This Useful Post: | jlatrace (11-04-2009) |
| | #5 |
| Supporting Member Join Date: May 2006 Location: Texas USA
What is the heater voltage coming out of the transformer?
__________________ WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personel. |
| The Following User Says Thank You to loudthud For This Useful Post: | jlatrace (11-04-2009) |
| | #6 |
Thank for all the replies. I am attaching a schematic of my build that I put together today. Tonight I will take some more voltage readings. I noted the voltage readings taken last night in red. I have not tubed the amp bcause of the B+ voltage issue.
| | #7 |
Right - you have a PT with an Ht VAC of 354-0-354 and you are using SS rectification and you are getting 500V B+, so your 450V filter caps and your 6V6s won't last long at that rate. having said that when you put the tubes in, the voltages should drop by 20-30V I guess, but still probably too high for 6V6s (unless they are JJ6V6S - but that is still pushing it). Neverthelss you can put those 32uF filter caps in series, with a 220k2W resistor in parallel with each cap to equalize the voltage over both caps - this will make the reservoir caps safe, but you will only end up with 16uF reservoir, but that shouldn't matter. (You might have to do the same sort of thing with all the filter caps if the DC voltage on them is above the rated maximum for the caps. You can put 6L6s in there but you will want to adjust the bias accordingly and you will want the OT load resistance to be about half to 2/3 of what the 6V6 OT load resistance is - one way of doing that is to can halve the speaker load on the existing OT. Another way of getting the B+ down is a string of reverse-biased zener diodes in series with the centre tap of the 354-0-354 winding to ground. To begin with try say half a dozen 5W 15V zeners in series. Have the banded ends (cathodes) pointing towards the chassis ground. That should drop the B+ by 90V or so, which will make is safe for 6V6s and safe for your filter caps
| The Following User Says Thank You to tubeswell For This Useful Post: | jlatrace (11-04-2009) |
| | #8 |
Thanks. Interestingly I pulled the ot from a tweed champ and its B+ at pin 3 was 388. I think I have a bias issue that is staring me ib the face but I cabt see it.
| | #9 |
If there are no tubes in it, any bias situation won;t matter. The only voltage readings that matter are taken with tubes in the amp.
| The Following User Says Thank You to Enzo For This Useful Post: | jlatrace (11-04-2009) |
| | #10 |
I had a 1 meg resistor range resistor in my bias section by mistake. The problem is found and solved.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Rare PT Find - what to build? | tedmich | Theory & Design | 17 | 10-06-2009 07:20 AM |
| Wanted - High Power, High Voltage, Audio Frequency Transformer Manual | Kim | Tubes (Valves) | 16 | 06-04-2009 03:32 AM |
| Where to find high quality Electrolytics Supply? | Siboney | Music Electronics | 7 | 06-01-2009 08:27 AM |
| using 230v mains voltage directly for high voltage | black_labb | Theory & Design | 6 | 02-03-2008 07:41 AM |
| relationship between high voltage supply and plate voltage | studioit | Theory & Design | 10 | 06-06-2007 01:22 PM |
