Go Back   Music Electronics Forum > Amplification > Guitar Amps > Theory & Design
Old 11-03-2009, 08:26 AM   #1
Music Man RD-50
I recently got ahold of one of these and have been using it as my main rig lately. It kicks ass! I can't believe that the clean channel, which is all I use, is all solid state pre and only tube in PA.
What's up w/ the voltage gain transistors on the power tube cathodes? Also are the power tubes in a "common grid" arrangement?
+30v on the grids and signal entering through the cathode?
Also the screens are insanely low compared to a typical Fender/Marshall etc... why is this?
lowell is offline   Reply With Quote
Old 11-03-2009, 07:47 PM   #2
Supporting Member
loudthud's Avatar
Those transistors should be described as providing current gain. They probably drive the 6L6's into class AB2 territory where you don't need high screen voltage. In short, the design is completely different than the typical guitar amp. I wonder what the primary impedance of the OT is.
__________________
WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personel.
loudthud is offline   Reply With Quote
Old 11-04-2009, 04:21 PM   #3
Supporting Member
Steve Conner's Avatar
Yes, you can think of it as a "common grid" arrangement.
The tube is activated by the voltage between grid and cathode. It doesn't care if the cathode stays in one place and the grid moves around (conventional amp) or the grid stays in one place while the cathode moves around (Music Man)
The tube might not care, but the driver circuit does. The cathode is harder to drive than the grid, because it collects all of the plate and screen current, giving it an effective impedance of only a few hundred ohms. But that's no problem for power transistors. They love high current, low voltage, whereas tubes love high voltage and low current.
So, another way of seeing the Music Man circuit is to say that the transistors provide the current gain, and the tubes provide the voltage gain.
__________________
"Transformerless is the way to go", said he, without a hint of irony.
Steve Conner is offline   Reply With Quote
Old 11-04-2009, 07:57 PM   #4
ok interesting. the only thing I don't get is that the transistors are in a voltage gain arrangement aren't they? It'd make more sense to me if the transistors had the signal leaving the emitter instead of the collector.
Old 11-04-2009, 08:01 PM   #5
Supporting Member
I recently repaired one of these amps and I'm in total agreement. That amp kicks ass!!
cjlectronics is offline   Reply With Quote
Old 11-04-2009, 08:20 PM   #6
Quote:
They look more like current sources to me, with the current set by the voltage developed across emitter resistors R51 and R54.
RudeBoy is offline   Reply With Quote
Old 11-05-2009, 12:45 AM   #7
...they're CATHODE MODULATED push-pull.
__________________
Old Tele man is offline   Reply With Quote
Music man circuit breaker merckx5312 Maintenance, Troubleshooting & Repair 4 04-02-2009 08:23 PM
Tone mods Music Man RD-50 lowell Mods & Tweeks 5 01-27-2009 01:36 AM
music man circuit breaker merckx5312 Maintenance, Troubleshooting & Repair 1 01-19-2009 07:13 PM
Music Man RD 110 lowell Schematic Requests 1 10-29-2008 05:17 AM
Music Man Capacitors WholeToneMusic Maintenance, Troubleshooting & Repair 13 09-16-2008 08:22 PM
