Go Back   Music Electronics Forum > Amplification > Guitar Amps > Theory & Design
Old 11-04-2009, 07:01 PM   #1
trevorus's Avatar
Transformer based Phase inverter for a small PP amp
What would be the advantages/disadvantages of using a transformer for a phase inverter, like in a balanced/unbalanced transformer for feeding 2 EL84's in push pull? I know power saving on the PT would be one advantage, but is there any real advantage beyond that?
trevorus is offline   Reply With Quote
Old 11-04-2009, 07:09 PM   #2
Jazz P Bass's Avatar
Transformer PI
Other than costing more, weighing more & being bigger, a center tapped phase inverter works very well.
You need a well made transformer. Both sides should have relatively equal output.
You may have to design in a compensatation circuit for the correct frequency response.
Hey, it is a transformer after all.
John G
Jazz P Bass is offline   Reply With Quote
Old 11-05-2009, 02:49 AM   #3
I've built a 2X6v6 amp with a transformer PI- my guitarist friend digs the sound.
Pluses: Very good balance/match between the two outputs.
Simplicity/parts count.
Can drive the tubes class AB2 for more output if desired.
No bias shift issues.
Minuses: PI transformer can pick up hum from PT, feedback from OT.
Really need a driver tube which can push some current- a 12AU7 or 6CG7 is good.
Slightly more expensive and heavy.
Difficult or impossible to apply negative feedback across entire power amp stage due to phase shifts in the PI x-mer. (I don't care for NFB, so it's a non issue for me.)
Driver stage is usually single ended and needs a well filtered power supply.
You can check out the Gibson GA-20 RVT and the Fender Musicmaster Bass amo (I think that's the right model on the Fender) for examples of commercial amps using transformer PIs.
Good luck with your project!
octal is offline   Reply With Quote
transformer phase inverter ? billybillybilly Theory & Design 20 12-01-2008 10:18 PM
Fixed bias, phase inverter AB1 PP... examples? bluefoxicy Theory & Design 9 06-14-2008 03:32 AM
would there be any advantage in having a pp amp wihtout a traditional phase inverter black_labb Theory & Design 29 11-03-2007 06:40 PM
AA270 Twin Reverb, bias & phase inverter JMadson Mods & Tweeks 6 10-25-2006 05:59 AM
Phase Inverter and Reverb Phase Daver Theory & Design 5 08-21-2006 05:25 AM
