| | #1 |
| Junior Member Join Date: Nov 2009
| Peavey Classic 20 - Oops
Hi all - new to the forum and I don't really know much about how tube amps work. I've got a Peavey Classic 20 that isn't working. I took the tubes out of the amp while traveling, and then mistakenly put them back in the wrong slots. The EL84's where the 12AX7's should be, and vice versa. I turned on the amp, quickly smelled a burning smell and saw a little smoke so I turned the amp off. Later I realized the tubes were switched. I've put them back in the right spots, and turned the amp back on. No more smoke, but no sound either. I know a good tech I'm going to take it to, but any idea how bad this is? I'm hoping it's something simple... Thanks in advance. |
| | #2 |
| Member Join Date: May 2008 Location: minnesota
Sorry about your situation, I just think it's funny that you knew enough to take out the tubes while traveling so they don't break, but you forgot to check where the tubes go... haha. Best case scenario you only need to replace the 2 pre-amp tubes that you put into the power tube slot because the power running through them would kill it... Worst case scenario, you fried something... I don't know enough to actually know what you fried, ha. Good luck. Hope you get some real answers from some people on here. There are a lot who know what they are talking about. |
| | #3 |
| Old Timer Join Date: May 2006 Location: NYC
You put high voltage on a grid,pin 7 and the heater,pin 9 of the 12AX7.Possibly fried a couple of resistors associated with them,would explain the smoke.Take the amp to someone who can fix it.
| | #4 |
OK, thanks for the replies. Sounds like it probably isn't too bad. I dropped it off at the repair shop yesterday.
| | #5 |
| Senior Member Join Date: Jul 2006 Location: Baton Rouge,LA
You most likely also fried the internal fuses.
__________________ KB |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Peavey Classic 20 Power Tubes Won't Light... | Roverjoe | Maintenance, Troubleshooting & Repair | 17 | 03-11-2010 01:32 AM |
| Peavey Classic 20 transformer source | antilog | Maintenance, Troubleshooting & Repair | 7 | 04-22-2009 03:03 PM |
| Peavey Classic 20 distortion when warm | lmolter | Maintenance, Troubleshooting & Repair | 10 | 04-04-2009 02:32 PM |
| Classic 20 repair manual | lmolter | Maintenance, Troubleshooting & Repair | 2 | 05-25-2008 03:13 AM |
| Adding an effects loop to a Classic 20 | Nalo1022 | Mods & Tweeks | 5 | 06-30-2007 01:04 AM |
