| | #1 |
| Junior Member Join Date: Nov 2009 Location: white,georgia
My amp just fried and i believe it was the two bias resistors R102 &R101 I cannot find out what the value and wattage is of these two resistors becouse they were chared. These amps get real hot becouse of the tubes so I put two computer fans on it to keep it cool ,but I forgot to turn it on this time.Has anyone else had a problem similar to this ? It would get so hot ,you could not keep your hands on it for more than 3-4 seconds. Thanks! Dwayne Last edited by fiddlemandwayne; 11-09-2009 at 05:06 AM. Reason: found typo and to ad more info |
| | #2 |
| Junior Member Join Date: Oct 2009 Location: Murfreesboro, TN
Sorry to hear about this. The Kustom Coupes are awesome sounding amps, but they are prone to high temp issues because of the biasing scheme. I haven't had a burnout, but my Coupe used to get so hot that the trem/vibe circuit would stop working. Like you, I installed a small multi-speed twin computer fan on the power tube cage. Once I did this, no more problems! I think these amps should come with a cooling fan as standard equipment. Sorry I can't help you on the schematic, but if you email Kustom, I understand that they will send you a pdf schematic, but they will also caution you that it will void your warranty. So if yours is still under warranty (mine is not) you'd be better off sending it to an authorized service tech. |
| | #3 |
| Junior Member Join Date: Oct 2008 Location: North Carolina
I replace those two resistors with 100 ohm 10 watt ceramic resistors,Also don't forget the two 47uf 100 volt electrolytic caps.One more thing to check are the 4.7k input grid resistor that go to pin #5 on the out put tubes.a quick and dirty test is to locate pin 5 and check for -25 vdc on all power tube sockets if so chances are the grid resistors are fine.The 100 ohm resistors help to lower the heat.thecorrect resistors are 82 ohm 10 watt.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| 36 coupe filament problem | jeffsjazz | Maintenance, Troubleshooting & Repair | 5 | 08-14-2009 06:17 AM |
| Kustom '36 Coupe | Euthymia | Schematic Requests | 1 | 04-30-2009 09:22 AM |
| Any info on the new Kustom Coupe 72 amps? | Steve A. | Guitar Amps | 2 | 03-13-2008 01:36 AM |
| Arcing in a '72 univox | Doug | Maintenance, Troubleshooting & Repair | 0 | 08-05-2007 02:57 AM |
| 72 Princeton overhaul? | sgmarshall | Mods & Tweeks | 2 | 08-09-2006 03:30 AM |
