| | #1 |
| Senior Member Join Date: Jul 2006
| Fender '94 Twin Amp Noise...
When I flip the standby switch, there's a static noise coming from the speakers. All front panel control pots are set at zero. And noisy with/without a guitar cord plugged in. The noise persists when preamp tubes V1-V6 are removed. The noise is gone when V7 (effects loop) or V8 (PI) are removed. It's not the tubes. It's not the plate resistors. It's not the power supply filter caps. I know because I replaced all those things. I've cleaned and retensioned all the tube sockets, too. I replaced the .022uF PI/power tube coupling caps C32/C33. I also replaced coupling caps C29, C23 and C26 which run between V6 and the PI via the effects loop tube V7. Noise persists. I also replaced power supply resistors 5W/1K R91/R154 and 2W/4.7K R103...noise persists. Any ideas as to what to check next to determine where the noise is coming from? Thanks for your help! The schematic is on page 2 of the link.... http://www.fender.com/support/amp_sc..._Schematic.pdf Last edited by acorkos; 11-09-2009 at 05:59 PM. |
| | #2 |
Hi acorkos I would have thought it would be a plate resister R146 even R 145 but you say you have replaced these. If you insert a jack plug in the "power amp in" dissconecting the first half of V7 is the noise still there ? That may help to narrow it down further. Maybe explore where the negative feed back comes in and components around the presence control. |
| | #3 |
| | #4 |
| Member Join Date: Aug 2009 Location: Seattle, Washington
It seems you've narrowed it down to V7b. any resistor connected to it is suspect. could one of the cathode resistors inject hiss in a follower? bad solder joint? |
| | #5 |
R140 off V7B (100K) was the problem
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Fender Twin Amp - need help | Jodo | Maintenance, Troubleshooting & Repair | 22 | 07-11-2009 06:27 AM |
| In New York, '94 Pro Tube Twin-Amp 100 Watt | darrellcheng | Flea Market | 0 | 03-13-2009 02:17 PM |
| need help for a fender twin-amp | Jose8a | Maintenance, Troubleshooting & Repair | 2 | 02-04-2009 04:39 PM |
| Question about biasing Fender 94 Twin...? | acorkos | Maintenance, Troubleshooting & Repair | 3 | 10-24-2008 09:43 PM |
| Fender Twin amp problem... | ubernerdsteve | Maintenance, Troubleshooting & Repair | 5 | 09-04-2007 02:13 PM |
