Originally Posted by
Resonator Guy
I used to have a number of amps made by Pine electronics, mainly because they were a Canadian company ( we can be chauvinistic up here in the frozen north ). The one you have is most likely a three tube model with no power transformer and a 50C5 output tube. It possibly has a 12AX7 preamp tube that has way too much gain for the circuit.
I could never get a real good clean sound out of any of these, but they did overdrive almost instantly with a tone some people found appealing.
There isn't much you can do with these to improve the sound. Try replacing every cap in the thing and test the resistors for drift.
They will power a 10 inch speaker, however I would try it with a borrowed speaker first so you aren't disappointed after buying a new Weber or some such.
All that said, I just recapped a Stagg PA head made by Pine. Two 12AX7s, two 6V6s and solid state rectification. I ran it through a 12" Jensen. Amazingly loud, sounds fantastic and is dead quiet. So there are good ones out there.
Keep hunting.
