Go Back   Music Electronics Forum > Amplification > Guitar Amps > Theory & Design
Old 11-10-2009, 05:23 PM   #1
Cathode Bias current draw
I would like to know the current draw on the 6v6s in my 5e3. It has a 250 ohm common cathode resister. Could I calculate the current draw per tube as millivolts by dividing the voltage read across the cathode resister by 250 and then dividing by 2? Thanks....
Mike
MikeT is offline   Reply With Quote
Old 11-10-2009, 05:47 PM   #2
The quick answer is yes.
Using Ohm's Law will give you a rough estimate of the current through each tube. Of course, it is unlikely that both tubes will be drawing exactly the same amount of current; one will be a little higher, the other a little lower. If you are running them close to their dissipation limits, knowing the exact current through each could be critical. If they are in a nice safe area of their operating range, then it probably won't matter much for just getting a general idea of the operating current.
cbarrow7625 is offline   Reply With Quote
The Following User Says Thank You to cbarrow7625 For This Useful Post:
MikeT (11-10-2009)
Old 11-10-2009, 06:14 PM   #3
Supporting Member
but since we are talking about a wire wound resistor here, and only a couple of hundred ohms, and about getting a measurement of a few dozen milliamps, then you should accurately measure the DC resistance of the cathode resistor first (you will need to unsolder the bypass cap to do this). Otherwise by just taking a guess that the 250R is actually dead on tolerance, your calculations could be out by something like 20% either way.
__________________
The Following User Says Thank You to tubeswell For This Useful Post:
MikeT (11-10-2009)
Old 11-10-2009, 07:33 PM   #4
Short, crude, rule of thumb, method...is your plate voltage <380vdc (plate to ground)...if so, don't fret it.
Might even take a few more volts before exceeding 14W per tube, if tubes are on the cool side. Either way, if you had 383 or 384v I wouldn't panic.
5E3 often slightly exceed 14W per tube.
If you want to measure plate current, then do so with a bias probe (it will come in handy in the future)...if you're happy with an appproximation, measure cathode voltage, or just the plate voltage. If you want to be "safe as houses" fit 330ohm cathode resistor & feel free to try a 5V4 recto and never worry about bias again.
MWJB is offline   Reply With Quote
The Following User Says Thank You to MWJB For This Useful Post:
MikeT (11-10-2009)
Current draw on 4, 6 or more power tubes Wally Music Electronics 3 09-09-2008 04:40 PM
Mains current draw lowell Theory & Design 0 05-19-2008 11:41 PM
grid current draw JC@ Theory & Design 7 09-30-2007 08:12 PM
1 ohm resistor to measure plate current w cathode bias studioit Tweed Builders 7 07-11-2007 02:30 AM
Transformer current draw for 2xKT88 clyde1 Theory & Design 3 10-16-2006 06:19 PM
