| | #1 |
| Senior Member Join Date: May 2008 Location: Webster NY
| Amp to Speaker/Cab Simulation - Your Experience?
Here is what I have. I've been comparing two setups. My first setup is a full-up amp modeling floor unit with amp models, cab sims, and effects. Although for the sake of testing, I turn off all the effects leaving it with a 57 Tweed Deluxe amp sim and 1x12 Tweed Deluxe cab sim enabled. My second setup is a real 5E3 clone amp with the speaker-out connected to a Palmer PDI-09 and the speaker-out of that driving a home-made resistive load @ 8 ohms. In both cases, I'm sending the XLR signal I want to a simple powered PA monitor. Tonally, these setups both sound pretty close to each other working with them at home. I have not tried gigging the Amp + PDI yet. I started playing with the PDI because I wasn't happy with how cold and weak the sound from the modeler was in my in-ear monitor. In my comparison test at home, both have a bit of a cold and metallic sound as compared to the 5E3 directly to its own Weber 12A125A speaker. I would roughly expect this result, but was looking for ways of improving it. A guitar speaker has this interesting mix of warmth yet sparkle that you don't get through basic EQ techniques. If I could find a little green box that sounded more like my Weber speaker, I would be happy. Let me know what you know. |
| | #2 |
| Supporting Member Join Date: May 2006 Location: Glasgow, Scotland
I experimented with a setup consisting of: Big wirewound load resistor DI box Alesis PEQ-450 10-band parametric EQ Old Digitech reverb box (for room simulation) Headphone amp I played with the EQ until I got a similar sound through headphones as I got from the amp's own speaker in the room. This took at least an hour and resulted in some pretty radical EQ. It doesn't emulate speaker distortion, but it seemed to work very well in spite of that. You could probably get a big improvement by just patching an EQ between your PDI-09 and your monitor, and adjusting to taste.
__________________ "Ohhhh miracle bulb shines feebly" |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Cab Speaker Wiring........ | amp boy | Maintenance, Troubleshooting & Repair | 5 | 02-26-2009 07:13 PM |
| SVT CL cuts out. Speaker Cab or Amp?? | dusty | Maintenance, Troubleshooting & Repair | 5 | 07-10-2008 10:00 PM |
| Help Dating A Speaker Cab (Fender) | spartadrive_in | Vintage Amps | 19 | 03-04-2008 07:44 PM |
| Pedal simulation? | hanumanlangur | Guitar Effects | 3 | 11-28-2007 12:13 PM |
| need help with wiring a speaker cab. | zippy | Theory & Design | 5 | 09-29-2006 01:40 AM |
