| | #1 |
| Junior Member Join Date: Aug 2008 Location: nola
| gk800rb
so a shorted speaker cable crawled into my cable case - i then used it with the gk 800rb and of course blew the fuse - so far i have only found 1 shorted output - Q20 - plan on replacing it and Q24 - what else would you check? - hmmm i see they use the same outputs in the 100wt section for biamp i dont use --no no,i wont do that - on side note - about 1/3 of amp set on end in katrina water for about 1 day - cleaned it up and working fine until now - oo3
| | #2 |
If an output transistor blows, then always check the resistors associated with it. No schematic handy, but I assume there are some ballast resistors - the 0.22 ohm or whatever types. And then we always want to check the driver transistors. Work with NO speaker load until you know the amp is not blowing fuses and not putting DC on the output. This is exactly the case where you want to bring the amp up on a variac while watching the mains current.
| | #3 |
thank you for input - i am out of practice in this area - checking some more still only finding the one transistor shorted - will have to order some parts - oo3
| | #4 |
| Junior Member Join Date: May 2009 Location: Minnesota
I work on these alot... I would recomend r48, 49, 50, they make test ok, but you may want to look on the potted side for cracks or discoloration,maybe consider just replacing them since you have to unsolder one side anyway.... also D10, R47,51 Also, a 60 watt light bulb in series with the transformer primary will keep you from reinjuring your newly installed components if you've missed something. ( unless you have the aforementioned variac and amp meter) Last edited by grooveman1961; 11-23-2009 at 05:26 PM. |
| | #5 |
| Senior Member Join Date: Jul 2009 Location: Phoenix, AZ
| Hmm. Seems like I've heard about that somewhere....
__________________ ST in Phoenix |
| | #6 |
| Yeah, back in the day when i was so broke I couldn't pay attention, I started working on a blown rb800 that I bought as a box of parts. I can't remember where I saw it either, but I made a rig with a ceramic bulb base. It saved me alot of parts. It may seem hokie, but it works. |
| | #7 |
Hi groove, welcome to the forum. I think Phos is funning with you a little. "Light Bulb Limiter" is a favorite around here.
| | #8 |
| | #9 | |
| Quote:
Acoustic 370 blows internal fuse when turned on As always, Enzo is right.
__________________ ST in Phoenix | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| GK800RB & Phantom power | StkIt2DaMan | Maintenance, Troubleshooting & Repair | 4 | 09-07-2009 12:49 AM |
