Go Back   Music Electronics Forum > Amplification > Guitar Amps > Theory & Design
Old 11-13-2009, 02:18 PM   #1
Amp Kat's Avatar
Reverb 12AT7 Tube Heat ?
Do any of you back off the voltage on the 12AT7 in the Fender reverbs ? If you do a touch test those tubes they just run so freaking hot that it bothers me as it seems it would burn out way faster than the others. I realize the 12AT pulls more current than a 12AX by Siemens but does it kill the tube quicker I guess is what I'm getting at ?
__________________
KB
Amp Kat is offline   Reply With Quote
Old 11-13-2009, 02:35 PM   #2
"Touch test" isn't really a test at all.
AB763 schem shows the AT dissipating less than 1.5W (.75W per triode), well below max dissipation, even allowing for rise in AC wal voltage. Some late SF's had a 820ohm cathode resistor, these often get changed back to 2200ohms/25uf bypass cap.
MWJB is offline   Reply With Quote
Old 11-13-2009, 02:49 PM   #3
Amp Kat's Avatar
Think I'm gonna do a current test because this tube is hot to the point of not being able to touch it and at that dissipation wattage it should be way cooler. Maybe there is a problem also. I don't know what a 1.5 watt dissipated tube feels like but this one is really,really hot.
__________________
KB
Old 11-13-2009, 02:51 PM   #4
Do the current test by all means, but Fender reverb 12AT7 tubes are usually too hot to touch comfortably.
Think about it, you would worry about a hot rectifier or a hot power tube (which is exactly what the 12AT7 is in this case).
The Following User Says Thank You to MWJB For This Useful Post:
Amp Kat (11-13-2009)
Old 11-13-2009, 03:17 PM   #5
Amp Kat's Avatar
Good enough
__________________
KB
Old 11-13-2009, 06:47 PM   #6
SF fenders ran the 12AT7 reverb driver with a 470 to 1k cathode resistor, which runs the tube way over dissipation spec. As MWJB suggests, 2k2 is the value needed.
pdf64 is offline   Reply With Quote
Old 11-13-2009, 07:21 PM   #7
Supporting Member
I've found out from experience that those BF (12AT7) reverb driver tubes wear out faster anyhow, even though each triode is designed for 5mA plate current.
__________________
tubeswell is online now   Reply With Quote
Super Reverb cooks Reverb Driver 12AT7 pbabadoo Maintenance, Troubleshooting & Repair 8 10-29-2009 12:59 PM
12AT7 for Reverb Driver & PI TheTinMan Tubes (Valves) 7 09-13-2008 08:06 PM
Reverb and Driver tube: 12AT7 or 12AX7? EETStudent Theory & Design 26 09-10-2008 05:01 AM
HELP!! Tubes 1-5 wont heat up. mjunkieguitar Maintenance, Troubleshooting & Repair 3 01-17-2008 11:35 PM
Heat proof pens mick Pickup Makers 4 11-24-2007 12:19 AM
