| | #1 |
| Junior Member Join Date: Nov 2009
Hi all. I am new to this forum and new to building. I stumbled on it searching for information about building a 5f1 Champ-like amp and troubleshooting noises. I am trying to make the amp somewhat smaller with the chassis on the bottom of the cabinet and tubes standing up next to the speaker magnet. But with a Jensen re-issue alnico speaker the 12AX7 tube had to share the side next to the power transformer and the 6V6, 5Y3 and output transformer on the other side. My questions are: 1) I have heard that the 12Ax7 should be as far away from the power transformer as possible. If so, is there any way shield it enough so that it could live right next to it? 2) If you wanted only one input jack how would it be wired? Bridge the 68K resistors or just use 1? Would you still use the 1 Meg resistor to ground? 3) Does it make any difference in the filament voltage if you don't use a pilot lamp? 4) Would the fact that the PT and 5Y3 are on opposite sides of the chassis and require fairly long wires cause problems? 5) Am I an idiot for even trying this? Thanks for any advice. |
| | #2 | |
| Senior Member Join Date: Aug 2008 Location: Phoenix
| Quote:
2. one 68k and 1meg to ground only. 3. Nope 4. The distance wont if you keep the cap on the circuits side 5. Necessity is the mother of invention | |
| | #3 | |
| Quote:
I will check into how expensive MU metal is before making another chassis. Could you explain what you mean by "keep the cap on the circuits side" in regards to the question about the 5Y3 wires running from one end of the chassis to the other? This is my first build and I am learning "on the job". The noise in the current (12AX7 next to the PT) setup sounds like a hum + a kind of very fast but not loud clicking that gets louder with turning the volume up. Is this oscillation one would expect with this setup? Thanks again for your kind reply | |
| | #4 |
I meant, don't run the unfiltered DC across the chassis. Also, keep the secondary wires nicely twisted together running along the corner of the chassis for best hum field reduction.
| | #5 |
| Junior Member Join Date: Nov 2008
Hi Hans - do you already have a cab? I've built some amps with the chassis on the bottom of the cab with the knobs on the backside like the old Gibsons had and had build the corresponding cabs particularly for use of the planned components. I said good-bye to the idea of a classical Fendrish cab desing and build them some kind put on the end (the small side on bottom and top). So you have enough space by moving the speaker higher and away from the chassis. For my current project - a 6V6-PP amp based on the Gibson GA8 (Gibsonette) circuit - I took the dimensions of a 5E3-Deluxe and turned it by 90 degrees. For me this was the most elegant way to avoid the kind of trouble you fear now. Over and above that you have some additional space on the surface of the chassis if you want to experiment with different OT positions in the case of "hum-chasing". Many kind greetings from Germany Arne |
| | #6 | |||
| Supporting Member Join Date: Feb 2007 Location: Wellington NZ
| Quote:
You may also want to put 10k-100k grid stoppers right at the grid pins of the pre-amp tube and 1k5 to 4k7 grid stopper at the signal grid pin of the output tube to kill unwanted HF Quote:
Quote:
Better if they are as close as possible, because of potential EMF coupling from wires. As a rule of thumb wires should preferably be kept as short as possible in order to avoid unwanted signal coupling. Best practice is also to twist the AC pairs together, as this helps to cancel out the EMF surrounding each individual AC wire - thus reducing potential sources of unwanted hum coupling into more sensitive signal wires (because the wires in the AC pair are in opposite phase to each other - while one is negative, the other is positive - hence the EMF in the space surrounding each wire cancels out if these are in close proximity)
__________________ Building a better world (one tube amp at a time) | |||
| | #7 |
Thanks for all the great info guys, I am thinking it would be better to make a new chassis and have the input tube and rectifier trade places. I guess I learned there is a good reason that all the amps are laid out that way We'll see what happens! |
| | #8 |
Arne, I have a cab built. it is a little smaller so there is less room for the tubes between the speaker magnet and the transformers. I tried putting the preamp tube on the side with the power transformer and found out this is not a good idea because the tube will pick up noise there. Also, the rectifier tube should be there so the wires can be shorter. This is my first build and I am learning many lessons. So ist das Leben. |
| | #9 |
Hans - a big part of our hobby is finding out how and if things work and trying out this and that - for me this is part of the fun. If I were you I'd try how it works and if it doesn't you can build a new cab and/or chassis and book it in the chapter "experience". Der Weg ist das Ziel (the path is the destination) Arne |
| | #10 |
| Good advise!
Thanks to all who responded to my questions I now have a quiet great sounding amp. You guys are the best! |
| Bookmarks |
| Tags |
| 5f1, champ, homemade, hum, noise, troubleshooting an amp |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| 5F1 New build | mstang01 | Debugging Your Build | 11 | 11-19-2009 09:06 AM |
| 5f1 build, s | pontiacpete | Debugging Your Build | 10 | 07-23-2009 04:59 AM |
| 5E3 tweed deluxe home build just died | thebigkevdogg | Maintenance, Troubleshooting & Repair | 10 | 08-01-2008 11:18 AM |
| Please take a look at my 5F1 layout | fabiomayo | Tweed Builders | 17 | 10-02-2006 01:23 PM |
| Latest home build :( | 496dart | Debugging Your Build | 11 | 08-23-2006 04:54 AM |
