| | #1 |
| Junior Member Join Date: Nov 2009
| Hola! Perhaps you awesome peeps can resolve my query on bias..
I own a Splawn Quickrod. Voiced pretty well, but I'd like to try either KT66 or 6L6 tubes instead of EL34. I've been told I'll have to perform a bias mod in order to accomplish this change. Now, I understand completely that Capacitors can store lethal voltages. Good thing I can drain them. So if I die attempting to follow your advice, you're off the hook now, and it is entirely my own fault when I find myself in a dark tunnel gazing at a bright light at the end of it. I'm basically just trying to prepare for a mod if I can't set my bias low enough to accomodate a 6L6 pair. |
| | #2 |
| Senior Member Join Date: Oct 2007 Location: Tucson, AZ
...CAUTION over ADVENTURE! ...have your local "qualified service technician" show you, that way you can WATCH how it's done correctly.
__________________ ...and the Devil said: "...yes, but it's a DRY heat!" |
| | #3 |
| Senior Member Join Date: Jun 2008
The 6L6's or KT66's will require a higher negative voltage, which the bias supply may not be able to produce if the amp is set up strictly for EL34's. For example, you might need -55v instead of -42 volts
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| FS: Awesome Parts-O-Caster with Lace Sensors | trevorus | Flea Market | 2 | 01-13-2009 07:12 AM |
| it's the old ohms query | LeoBurke | Guitar Amps | 8 | 10-22-2008 02:06 PM |
| 5E5a schematic query | tubeswell | Tweed Builders | 1 | 06-03-2008 12:18 PM |
| Volume pot query for an SG | Umfufu | Guitar Tech | 8 | 11-05-2007 10:27 PM |
| Awesome answering machine message today | WolfeMacleod | Pickup Makers | 15 | 07-26-2006 03:53 PM |
