Go Back   Music Electronics Forum > Amplification > Guitar Amps > SUNN
SUNN New home of the old SUNN Forum
Old 11-14-2009, 09:23 PM   #1
Sunn beta lead user manual?
Can anyone help with a copy of the operating guide for this amp?
unparalleled is offline   Reply With Quote
Old 11-15-2009, 09:57 AM   #2
NO ONE CAN HELP? Bump.
Old 11-21-2009, 03:36 AM   #3
Supporting Member
loudthud's Avatar
There really isn't a user manual online anywhere. Basically there are two channels. When you plug into either channel, an LED will come on. If you plug into the "Both" input, both LEDs should come on. If you have the optional footswitch, you can select either channel or both at the same time when using the Both input. Each channel has an Effects loop and there is a Master Effects loop that is just before the power amp after the two signals are mixed together. The output is 100W at 4 ohms.
__________________
WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personel.
loudthud is online now   Reply With Quote
Sunn Beta Lead Restoration antoniobsr Maintenance, Troubleshooting & Repair 10 02-16-2009 08:41 PM
Sunn Beta Lead, no reverb on either channel redhare SUNN 2 01-13-2009 01:19 AM
Sunn Beta Lead blown? Perique Maintenance, Troubleshooting & Repair 1 09-30-2008 09:49 AM
sunn beta lead reverb pots? deadmeat13 SUNN 1 07-31-2008 02:13 AM
help with sunn beta lead seadflo SUNN 7 07-05-2008 12:45 AM
