Where did you get the layout drawing?
>>> If you mean the PCB one..I pulled it off a University web site. It looks like a drawing/diag that can be used for PCB production. Odd that it is so perfect a match...may have been a students project to create a reproducible PCB circuit for some class? Some students have all the luck...all I got to play with was the tinkertoy set for Organic Chemistry - not what I would call a good time.
Looking at it, and your schematic, I see things like C11 across the incoming mains, R20 on the breakaway LED board, J3 with R2 for headphones, etc. Way too many coincidences to be anything else.
>> I compared it to the pictured I posted here for the amp PCB and it appears to be an EXACT copy.
I don;t
recognize it, but using the information shown, I can conclude the layout and schematic are for the same amp.
I don;t know about historically conventional. It is two tubes on a circuit board with controls and jacks along one edge. Nothing odd about it, but how many ways can a board be laid out with two tubes anyway?
>> I have no clue, that is why I am enjoying learning bout tube amps from the more knowledgeable. Interesting that other 5 watt amp mass prod PCB boards to my eyes look more dissimiliar than similiar, with exception of the number of tubes.
What did they base it on? Nothing. They sat down and said "why don't we make a little 5-10 watt tube amp, I think there is a market for it." And they proceded to knock out a design. No reason in the world to "base" it on something. A two tube amp is something any competent tube guy can sit down and draw up on a napkin sitting at a bar.
The two preamp stages have 100k plate loads and 1.5k cathode resistors, absolutely the most common arrangement, and right out of the RCA book. Basic single ended power amp and a simple power supply. it is a nice little amp, but it is utterly conventional.
You want to play with the circuit? All the basic rules apply, cathode bypass caps affect both the gain and the low end response. You can play with the plate load resistance to affect gain. You could probably shift the tone control response some with different cap values. And the coupling caps between stages can be changed to affect frequency response. You could mess with R17 to affect the power tube drive. Hell you could even try a 12AY7, might work. Or a 5751. There are only 20-25 parts in the entire signal path, so there is a limit. Oh, you could change R12 and experiment with changing the B+ level in the preamp.
>> I am hesitant to whip out the iron on this amp as I would miss having a small tube amp to play my racket through
. I have already replaced tubes and the speaker. The Speaker upgrate to 8" Weber Blup Pup was worth while indeed. Before I do anything I will order/ build the cables I have selected. Of course I will post up my aural results.
>> Thanks again Sir for your thoughts.
CS
Cables. yes there are dirt cheap cables that sound dull, and there are $50 that sound great. But there are plenty choices in the middle. The leap from $3 to $30 is an obvious sound, but I am not convinced myself that from $30 to $50 is such an obvious step.
