Go Back   Music Electronics Forum > Amplification > Guitar Amps > Theory & Design
Old 11-19-2009, 03:30 AM   #1
Orange Rockerverb 100
Id like to incorporate some of the preamp of this fine sounding amp into a home brew.
I have the scem here but its kinda confusing...
Looks to have 6 pre tubes.
1 loop
1 reverb
1 pi
3 for clean/dirty
Id like to use the Dirty circuit without the rest . (no loop / clean ch. / verb)
Would this be ... V9a-b , V8a-b , and then just out to the PI tube?
The output being the 500K pot RV8 ?
Would anything have to be between the pot and the grid of the PI ? Maybe a 1meg
sorry--i just have the paper schematic here
Valvehead is offline   Reply With Quote
Old 11-20-2009, 09:49 AM   #2
dan___o's Avatar
Here's one I prepared earlier:
Preamp Schematic
And here's the layout I did for it (full amp minus reverb). Needs checking though... Still Beta
To answer your question though,
V9 and V8 are for the dirty channel.
V10 is clean
V7 is loop
V6 reverb
V5 is Phase inverter
So yeah, as you say Master volume pot straight to the PI (the 47n) omit the series 1M you shouldn't need it.
Having said that though, the loop probably will affect the overall sound of the amp, so if you're going for the authentic 'rockerverb' sound you might want to add it. Otherwise leave it out. It may well sound better without it.
dan___o is offline   Reply With Quote
Old 11-20-2009, 08:20 PM   #3
k, thanks.
with the loop turned 'off", does it affect the circuit? a far as gain ?
actually , it looks like its always in the path which would add 2 stages- correct?
Old 11-20-2009, 09:36 PM   #4
dan___o's Avatar
Quote:
Originally Posted by Valvehead View Post
k, thanks.
Yeah, the loop is always in the signal path. When you have two extra tube 'gain' stages in the path it will always colour the sound (for better or worse).
As far as gain, The loop shouldn't really affect the amount of gain (as in clipping/distortion). they are both clean stages. You will loose some voltage gain on V7A (cathode followers have gain less than 1) and on the voltage deviders before the CF. The recovery stage V7B is set for low voltage gain (~20). I imagine the gain of the loop was designed for a gain of around 1, as in no gain, but no loss.
Marshall EL34 100/100 Poweramp schematic RomanMtz Maintenance, Troubleshooting & Repair 7 11-12-2009 05:04 PM
RockerVerb 50 blowing HT fuses DoyleFan Maintenance, Troubleshooting & Repair 11 09-22-2009 04:02 PM
Orange Rockerverb - Reverb -real 'bong-ie' sounding Mars Amp Repair Maintenance, Troubleshooting & Repair 2 07-07-2009 01:44 PM
Where to buy custom cabinet for Orange Rockerverb 50 head jglover51 Cabinetry 1 04-06-2009 02:58 PM
Orange Rockerverb Noise Problem brylord Maintenance, Troubleshooting & Repair 1 04-24-2008 06:23 PM
