Go Back   Music Electronics Forum > Instrumentation > Guitar Tech > Pickup Makers
Old 11-20-2009, 02:32 PM   #1
Grub/Set Screws as pole pieces - which is the most magnetic?
I need to order some grub screws for my Sustainer coils ....they're available in two finishes that suits my needs....
Zinc coated steel
Stainless steel.
Now I'm pretty sure I have some zinc coated steel screws in my screw drawer that aren't magnetic in the slightest (there again I could be wrong - they might not be steel inside, but they are bright/shiny!), so can aynone say that if steel is given a zinc coating that it loses some/all magnetism?
Of the two types above, which would be the most magnetic?
peskywinnets is offline   Reply With Quote
Old 11-20-2009, 05:24 PM   #2
If your screws Pesky have no magnetic properties at all then they are stainless. Not all stainless is nonmagnetic but most commercial stainless screws are. Never found zinc plate to stop any properties at all as I use a lot in another field and a dropped box of them is quickly picked up with a big magnet.
jonson is offline   Reply With Quote
Old 11-20-2009, 07:11 PM   #3
Pickup Maker
David Schwab's Avatar
The zinc plated steel is the one to use.
__________________
Those who create are rare; those who cannot are numerous. Therefore, the latter are stronger. - Coco Chanel
www.sgd-lutherie.com
www.myspace.com/sgdlutherie
www.myspace.com/davidschwab
David Schwab is offline   Reply With Quote
Old 11-21-2009, 01:03 AM   #4
Zinc is fine unless you want to anneal them indoors over a torch. The zinc fumes are very toxic so do that out of doors.
David King is online now   Reply With Quote
Old 11-21-2009, 02:12 AM   #5
Possum's Avatar
You can remove zinc plating quickly with muriatic acid, I do this all the time....
__________________
http://www.SDpickups.com
Stephens Design Pickups
Possum is offline   Reply With Quote
Old 11-21-2009, 03:32 PM   #6
Quote:
Thanks to you all for replying.
I've no issues with the zinc plating *unless* it impedes the underlying magnetic qualities of the grub screw.
Old 11-21-2009, 04:06 PM   #7
Here in the uk and probably everywhere else they should be available chemically blacked as well. I know unbrako's range is huge. We call, as you may know Muriatic acid/ Hydrochloric over here in the uk and that you can get a small quantity from your local plater. You can also do your own blacking by heating them in a wire basket till they are cherry red and dunking them straight away in some real black dirty sump oil. That has no effect magnetically whatsoever.
Last edited by jonson; 11-21-2009 at 04:11 PM. Reason: hadn't finished when it zoomed off. must be hitting wrong keys in me old age.
Old 11-21-2009, 06:33 PM   #8
Pickup Maker
Quote:
I have a box of the black set screws I'm using on a project. It's the same type of screw that DiMarzio uses.
__________________
Alignment Of The Strings Over The Pole Pieces spud1950 Pickup Makers 48 03-12-2009 06:05 AM
Magnets as pole pieces, *and* slugs? j. pierce Pickup Makers 11 11-14-2008 01:29 PM
Dimarzio pole pieces, hex head ShannonH Pickup Makers 24 04-11-2008 03:23 AM
Gold Pole Pieces dayvo Pickup Makers 4 06-26-2007 11:56 AM
Inductance w/wo pole pieces KT66 Pickup Makers 16 03-26-2007 07:52 AM
