Go Back   Music Electronics Forum > Instrumentation > Guitar Tech > Pickup Makers
Old 11-20-2009, 06:32 PM   #1
Wiring Diagram
I am putting together a wiring diagram reference book and just completed my first diagram. I am looking for comments. Would you rather see it differently in terms of component design? It will have to stay in black and white due to printing costs, but i am open to other ideas.
automan is offline   Reply With Quote
Old 11-20-2009, 06:34 PM   #2
In the big space on the left is going to be a parts list
Old 11-20-2009, 07:01 PM   #3
Dave Kerr's Avatar
You might want to be more consistent when indicating where wires cross without making a connection, or better yet go with an explicit black dot when you do mean there to be a junction.
Dave Kerr is offline   Reply With Quote
Old 11-20-2009, 07:08 PM   #4
Yeah, I was going to go with arcs, but decided to go with the black dot junction.
Old 11-20-2009, 07:34 PM   #5
Dave Kerr's Avatar
And maybe make perfectly clear the perspective - are we seeing the bottom of the pot, or is it top view? The jack graphic may not be clear to all in terms of which is the tip and which is the sleeve.
Old 11-20-2009, 08:15 PM   #6
I am going to have a legend in the beginning of the book with all that info and I also think I am going to change all the grounding paths to dotted lines.
Old 11-20-2009, 11:54 PM   #7
I would make it clearer that soldering tips of the pots are actual parts of the pots (i.e. I would link the tips to the circle describing the pots).
On a totally different point of view, I think I would put disclaimer / TM marks to the trade marked names listed to publish this.
__________________
www.bourvonaudiodesign.fr
Yves is offline   Reply With Quote
Old 11-22-2009, 04:39 AM   #8
Possum's Avatar
What value pots, what value and what kind of capacitor? Where does the battery go?
__________________
http://www.SDpickups.com
Stephens Design Pickups
Possum is offline   Reply With Quote
Old 11-22-2009, 06:39 AM   #9
This is the second format draft. The grounds are now dashed, each solder point is a dot, and the parts list has been added. Any other critiques?
ps: I know the switch isnt listed on the parts. It has been fixed in the original.
Old 11-22-2009, 09:25 AM   #10
If you do a small 180 degree curve (half a circle) where lines cross over but don`t connect it will make the schematic clearer. Also a standard earth sign you donīt need the green circle, just the inverted christmas tree.
CHEERS
Andrew
the great waldo is offline   Reply With Quote
Old 11-22-2009, 05:07 PM   #11
I would do the following:
Clearly say if this is the view from the front (player side) or the rear (cavity side.
Mark each pot with a symbol, like P1, P2, P3.
Identify the function of each pot (volume, tone, et al) and switch.
Mark each switch with a symbol (S1, S2, et al).
Say if the pot taper is linear or logarithmic. "Audio" isn't quite clear.
Mark the capacitor with a symbol, say C1.
Use the symbol names in the parts list, so it if perfectly clear which component goes with which description.
Joe Gwinn is offline   Reply With Quote
The Following User Says Thank You to Joe Gwinn For This Useful Post:
automan (11-22-2009)
Danelectro U2 - Wiring Diagram spartadrive_in Guitar Tech 17 01-13-2010 04:13 AM
please make me a wiring diagram for emgs. 91sport_tn Guitar Tech 9 03-27-2009 07:34 PM
Wiring Diagram for 67 Firebird III with 3 P-90's? voodoochild Guitar Tech 4 08-05-2008 01:58 AM
help please! wiring diagram 4 electric bass camg Music Electronics 5 05-20-2008 04:14 AM
1974 SG Standard wiring diagram Rob Mercure Guitar Tech 1 03-11-2007 08:46 PM
