Results 1 to 26 of 26
Thread: Alternatives to diode clipping???
    Sep 2006
    109
    I have a Zendrive and a Barber Burn Unit Small Fry that I borrowed from a friend at my house right now. I've been taste testing these against my Nady TO-2 (a high voltage tube pedal (1 tube) with removed clipping diodes), a DOD 250 overdrive (with greatly emasculated diodes and the vintage spec. .01 input cap for max fatness), and a stock Dano Drive.
    I think the Zendrive is extremely overrated. I like the Small Fry somewhat better. The Dano actually sounds purty great with the distortion below halfway. The DOD sounds really great if I have just a very little clipping on it. The Nady doesn't distort much since I removed the diodes but what distortion it does make absolutely distroys the others. The difference is obviously the clipping diodes. I hate the damn things. They sound fuzzy and buzzy, have unnatural decay characteristics, they kill your dynamics, they have a too easy sustain that just doesn't sound real. Shall I go on? Great strides seem to have been made of late with the EQ aspects of pedal design, but always there's that attack of the killer bees thing going on underneath.
    Is there an alternative to diode clipping in pedals? Surely we can do better than this.
    I've always just used clean boosters to overdrive the amp (which is essentially how I'm using the DOD and the Nady) but the volume, my god, the volume! Sometimes it's just not practical.
    What say ye?
    Dec 2008
    Wernersville, PA
    5,369
    clipping diodes
    how about a blue LED?
    May 2007
    pacific north west
    5,891
    Quote Originally Posted by Boy Howdy View Post
    First, diode clipping doesn't have to be buzzy and fizzy, or have an unnatural sustain. And tube clipping isn't always round and warm. It too can be buzzy and fizzy. Don't give up on pedal devices. There are many good ones out there. Some do employ alternatives to plain diode clipping like transistor clipping and LED's which both produce harder clipping than tube saturation (but not tube cutoff) but have a more organic feel than common diode clipping devices.
    Speakers can have a profound effect on distortion character. A speaker that is too bright will characterize all the bad stuff happening in the higher order harmonics of diode clipping circuits. But a dark(ish) speaker seems to even things out and hide the uglies. Once you get there you may find some good things about diode clipping. It seems to stay tighter on the bottom end even when a fatter kind of distortion is used. small amounts of diode clipping are very good at getting that "still sounds like the clean tone but has an edgy sustain" sound. Marshall has built it's sound on internal diode clippers for over a decade.
    Having said that...
    I also prefere tube distortion, even if I do recognize some merits of diode clipping. As far as things getting too loud, well, thats phase inverter and power tube clipping. You can't get exactly that sound without overdriving a power amp circuit. I used to get really good results with a master volume on my Marshall 1959RI. I installed the MV and ran a BOSS GE7 EQ pedal set to roll off a little highs and lows as a clean mid boost to overdrive the front end (channels jumpered of course). It was a very solid and "classic" rock sound with generous sustain. Preamp tubes do clip somewhat like power tubes. But with the exception of crossover distortion (where the AB waveforms meet) there is very little cutoff clipping with power tube distortion. Overdriven preamp tubes do clip harder because of the "cutoff" portion of their class A operation. You might try a master volume and a clean boost pedal. If you find the cutoff clipping of preamp tube distortion unpleasant, like diode clipping, then your only other alternative is to buy an attenuator and enjoy your power amp distortion.
    Chuck
    Supporting Member
    Staffordshire UK
    1,813
    Or fit a dual pot type mater vol between the phase splitter and power tubes. They can work really well.
    2,301
    One of the reasons some folks do not like diode clipping is because one pair or locus of diodes is doing all the heavy lifting. When distributed over multiple loci,the sound can become much more palatable.
    here's a circuit from Bernie Hutchins that presentsd an interesting approach to diode clipping:
    And another from the late Fred Nachbauer:
    Sep 2006
    109
    Actually, I couldn't find blue LEDs locally when I worked on my DOD, so I went with yellow in series with the silicon diodes already in the unit. Still distorts plenty and/but greatly increased its boost capabilities.
  7. #7
    Sep 2006
    109
    Yeah, Chuck, thanks. I've tried all of that at one point or another over the years. But with old amps some options work better than others. I modified my Traynor, put in a slightly tweaked JTM 50 circuit, and I converted two of the input jacks into a line out/in loop so I could use an outboard master volume. That gets me there for certain sounds, but then trying to get back to clean sounds ... you need channel switching.
    And then with my Sunns, they don't really distort very well (I swear I think Leslie West used something other than Sunn to record 'Mississippi Queen' - anybody know that story?). They only have one preamp tube, so not a lot of preamp gain to be had. They sound okay for distortion, nothing to write home about though. But I do love those amps for clean stuff. (note: the 1st stage cathode bypass cap needs to be changed to get a REALLY great guitar sound - I went with a 2uf.). If I could only come up with a great sounding and versatile distortion unit, I'd be in hog heaven with those amps.
  8. #8
    Sep 2006
    109
    Hey Mark, have built either of those? I'm a rank (yes, I stink) amateur when it comes to electronics. I'm not real conversant with some of this stuff. Looks like that's only part of the circuit in the top example, am I wrong?
    I spent more time over the weekend with these borrowed (and my own) pedals. That Dano Drive is an amazing little pedal, makes me want to get the OCD it's supposedly a clone of. I especially like it set with the gain set all the way to min. Sounds like a small tube amp at that settting. But of course I really need something to do the high gain, singing sustain thing. Something like the Zendrive. Which sings very nicely, but it's tone is just so thin and unnatural. The Barber sounds much better (tonewise) for that kind of thing, but my god, it has so much of that diode "aftertaste" as I call it, as to be almost unusable.
    Does anybody currently make these multiple loci pedal circuits?
  9. #9
    2,301
    No, I haven't built either, but I have played with "dual clipper" units that insert diodes at more than one place.
    The Big Muff Pi is the "classic" dual clipper, with two stages using a diode pair for clipping. But there are other ways. For example the softness of the clipping can be varied by means of a small resistance in series with the diodes. So, imagine you have two op-amp gain stages, each with a diode clipping pair and a resistor in series. The first stage might use 2 germanium diodes to set a low clipping threshold, but make the clipping softer by means of the resistor and the use of modest gain. Now, you follow this with a second stage that applies more gain - though not very much is really needed - and uses a pair of silicon diodes or even a 2+2 diode arangement, again with a series resistor to "soften the blow".
    Because the 2nd stage has a higher threshold for clipping, what happens is that the first stage clips a bit, and when you really dig into the note, the 2nd stage then adds more clipping to an already slightly clipped signal.
    Important in all of this is proper toneshaping and filtering of the signal. The first stage should have much of the upper treble rolled off in order for this arrangement to sound good.
    here are some examples of my own experiments: http://hammer.ampage.org/files/The_Crank.gif
    http://hammer.ampage.org/files/Chaos.gif
  10. #10
    Jun 2007
    367
    I personally like diode clipping. What is not often realised is how many different variations it can have:
    - Diodes can be referenced to DC voltages to increase the clipping threshold voltage. I have also experimented with an idea of dynamically varying this DC reference voltage based on signal's RMS amplitude. Sort of a "sagging" simulation.
    - Diodes can be connected in series, in series with resistors, in series with capacitors and in series with different types of resistive and capacitive "ladders" (and combinations of all those) to shape the transfer curve.
    - Diodes can be replaced with FETs, Zeners, LEDs, gate-source junctions etc. (Although I have found that this has quite minor effects unless change in forward voltage is a drastic one)
    -Diode clippers used in a feedback loop can be taken after a resistive divider located in feedback loop to increase the clipping threshold. They can be even fitted to active tone controls.
    - You can phase split the signal, clip each of the two signals individually and then combine the signals. When the signals are summed the "clean" signal half will correct the "distorted" half somewhat, resulting into softer clipping effect similar to that taking place in push-pull tube amps.
    - Asymmetric clipping arrangements can be used and they can be divided to multiple capacitively coupled stages to make the signal interact with DC offsets accentuated by asymmetric clipping process. Combine this with the previous scheme and you can even introdude crossover distortion caused by DC shifts. Just like in push-pull tube amps.
    - Pre and post clipping equalizing can be used to create drastic effects on tone. Using effective and appropriate equalizing scheme is pretty much the heart of any distortion-based circuit. Even the cunniest distortion stage will most likely sound extremely pathetic if it's combined with a high-bandwidth equalization producing farting low end and a screeching ice pick top end.
    - etc.
    It's all about using these types of diode clipping techniques (and other I likely forgot) effectively. There is no single tone in diode clipping. The tone comes from the whole circuit.
  11. #11
    2,301
    Well-stated. Thanks.
  12. #12
    Sep 2006
    109
    Quote Originally Posted by teemuk View Post
    So it seems. I took the diodes out of my DOD250 and that awful fizzy decay sound was still there. In this case, at least, it appears I have wrongly accused. The distortion in the IC (presumably) is not very pleasant (anybody got any suggestions for improvements?). I turn the gain down until I don't hear much, if any, distortion. Makes a really nice booster though.
    That said, I hear the same sound (that fizzy, crackly decay), but less pronounced with other pedals, of course. The Small Fry is particularly bad. The Zendrive not so much, but then they roll off the high end somewhere other than with the tone control. BTW, Mark, I hate that sound. Always have. I like total clarity in the note. I have another old Nady unit, the original TD-1 (I have the recent piece of crap Tonebone copy too, hate that thing). The original TD-1 has a 470pF cap going to ground just before V2 and before the clipping diodes. Totally ruined the sound for me. I cursed that thing for years before someone finally pointed out to me that that cap, which passes for a tone control, the only tone control in the unit, was responsible. I ripped that sucker out and am much happier with it now (despite the poor sounding diode arrangement). I've heard this phenom in many many pedals, this distortion -> treble rolloff -> distortion thing (often with no additional final tone control). I call it crunchy mud. Makes the skin crawl. I realize that in the hands of a designer with ears this doesn't necessarily have to be the case though. No offense.
    Thanks for what you wrote above teemuk. Lots to study there.
  13. #13
    Sep 2006
    109
    Hey Mark, I have some questions about this Dogzilla circuit, if you don't mind.
    Is that just an EQ unit? Why is the diode configuration called a limiter? Is it intended, as with a limiter proper, to prevent distortion, in which case it might be of little use for the purposes being discussed here? (is that a question?) This multiple loci diode arrangement, is the theory to distribute the distortion over multiple frequency bands? It looks like a simple enough circuit (the diode configuration, that is), any reason I couldn't just hack that into a pedal? Why isn't this or something similar done by pedal makers? If it deals with fizz it would be well worth it, so it would seem.
    Oh, another one: I noticed on the OCD and the Dano Drive pedal they have caps bypassing the diodes (.01 for the OCD and .001 for the Dano), is the idea here to pass some unaffected signal, to give a cleaner, more dynamic edge to the tone/signal/note?
    Thanks in advance.
  14. #14
    2,301
    Sorry for the slow response. Out of town.
    In theory, a simple diode pair, as used in so many distortion units, IS a limiter, in that it clamps the amplitude at a fixed maximum, whilst still permitting lower amplitudes. However, they become distortion units because that simple diode action has a "hard knee" and introduces a lot of additional harmonic content in the process. The multiple diode arrangement for the Dogzilla is to provide a much softer knee, by havng the overall conduction dependant on the joint action of many steps of diode conduction. Ideally, this should provide a cleaner limiting than that provided by a single pair of diodes.
    Running a cap in parallel with clipping diodes simply reduces top end. Nobody likes the fizzies.
  15. #15
    Oct 2009
    44
    Take a look at the original page describing this. There is a description of why he calls it a limiter. There are also some simulation curves there that show the overdrive effect of this circuit. I modeled it in spice, tried some variations etc. By biasing appropriately it is possible to get a nice asymmetrical limiting effect and distortion (for those that want that sort of thing).
  16. #16
    Senior Member tedmich's Avatar
    Apr 2008
    PDX
    1,220
    Quote Originally Posted by Mark Hammer View Post
    see also PAiA's Quadrafuzz:
    PAiA: Quadrafuzz Design Analysis by Craig Anderton
    LEDs in the pre tube cathode bypass are reported to sound very good, see Merlin's discussion on this.
  17. #17
    2,301
    The Quadrafuzz was a good start to an idea. Unfortunately, one of the things Craig Anderton didn't do with it was adjust the gain of the different bands to produce the same degree of clipping in each. And with LEDs for the clipping elements, that posed a problem.
    But, yes, the basic concept is a useful one.
  18. #18
    Mar 2010
    Boston
    1
    Boy Howdy, I have a Nady To 2 as well and I'm interested in the removal of the diode mod you did. Can you post pics or otherwise tell me how I can do this? It looks like they must be mounted to the sheet metal holding the tube and circuit board...
  19. #19
    Apr 2008
    Oceanside, NY
    1,642
    I am surprised that no one has yet mentioned opamp clipping (either "hitting the rails" with a low-voltage supply, or by using an opamp in open-loop mode), as well as MOSFET buffer clipping i.e. using multiple stages of MOSFET buffers (e.g. CD4049) biased in a linear fashion to achieve "tube-like" clipping. Neither one of these uses diodes.
    FWIW- any circuit that clamps the signal to a pre-determined level i.e. has non-linear output, is technically a limiter.
    John R. Frondelli
    "Mediocre is the new 'Good' "
  20. #20
    2,301
    I find that 4049-based circuits give a nice grunt. Of course, I tend to use bandwidth-limiting cap values, so I don't hear any fizzies that might be there. But, with that caveat, yeah, do consider something that uses a 4049 or 4069.
  21. #21
    Apr 2008
    Oceanside, NY
    1,642
    That's what I also like about the 4049 circuits. It has been done in guitar amps, going back to the Sunn Beta Lead series, and is easy to implement in a pedal. In ANY distortion design, even tubes, you need bandwidth limiting, so there is nothing wrong with applying these techniques across the board. For me, the most important step is initial low-frequency cut BEFORE distortion stage, or the intermodulation distortion can get real nasty. That applies to amps as well. I generally apply high-cut AFTER distortion, as the odd-harmonic edge tones and the resulting IM distortion they create adds "snarl". THEN it's time to cut back on those "fizzies". However, there's no free lunch. Too much high-frequency gain, and you can create an oscillator.
    John R. Frondelli
  22. #22
    2,301
    Not that there is anything wrong in your approach, but I take a different one. I prefer to tame the high end before hitting a clipping stage, and then gradually "spool out" the top end. The basic strategy is to avoid production of harmonics of harmonics of harmonics. Keeping upper harmonics safely away from the clipping threshold also tends to emphasize/spotlight lower-order harmonics.
    Case in point. I adapted Craig Anderton's initial "Tube Sound Fuzz" that appeared in Guitar Player ( http://gaussmarkov.net/layouts/49r/49r-project.pdf ). His later one that appeared in the EPFM book, and was further developed by Jeorge Tripps as the Way Huge Red Llama pedal, simply uses a 4049 on its own. In contrast to those, I used an op-amp input stage that allowed me to shape the tone of the signal hitting the*MOSFETs in the 4049. I recognize that distortioin is always a matter of taste as well as gear employed, but I find I prefer the arrangement shown over the bare 4049.
    You will note that the bandwidth-limiting caps in the 4049 stages also tame the treble. This is pretty much my go-to pedal if I'm "in a Mike Campbell mood" that day. A meaty tone with some bite, but not overly strident, and certainly not fizzy. The resonant boost section of the circuit shown is not required; it's just there to make productive use of the second half of a dual op-amp.
    Stellan Lehrberg in Sweden pursued this strategy evern further with his "Slowfinger" ( FortuneCity Web Hosting ). although from the soundclip, his appears to have more sizzle than mine.
  23. #23
    Apr 2008
    Oceanside, NY
    1,642
    Y'know Mark, it all depends on what the sound in your head is, and what you are trying to achieve. Everyone hears and wants something different. It's ALL cool! If everyone heard it the same, there wouldn't be so many choices in effects and amps. My approach is: if it sounds good (and nothing is smokin'), it IS good!
    John R. Frondelli
  24. #24
    Sep 2006
    109
    Hey classtone, don't do it!
    Yeah, lately I'm kind of regretting removing the diodes from mine. Let me explain.
    Lately, I've been using the TD-1 (80s model) a lot (it's very similar to the TO-2). Since I removed the 470 pF cap to get back the treble at that stage of the circuit I find that if I use a 7 band eq after the unit I can get some really great sounds.
    The TO-2 is a great unit as is. It could use a bit of bottom maybe. I changed the second coupling cap to a .01mf on mine but I think that's a bit much, a .005 would probably be just about right. But it's fine as is.
    As for removing the diodes, the only way the pedal is really useful that way is 1) as a volume booster to overdrive the amp's front end (It get's REAL loud that way. The amp must have a master volume to control it.) and 2) in my amp's pre amp out/in loop. In this mode the amp's preamp overdrives the TO-2's tube. It sounds great like that, but again, very loud.
    If I were to do it again, I probably wouldn't. If you do this mod make sure that you can find your way back to stock again. That's where I am now, trying to figure out which ones of all those holes the diodes came out of. And that circuit is a bit delicate what with all those wires to come loose.
    All that said, If you want to do this mod, instead of removing the diodes, remove just one leg (so you can easily reverse the mod) of the electrolytic cap just before the diodes. This will remove the diodes from the circuit and is less work, and is more easily reversed.
  25. #25
    Jul 2009
    London
    4
    It's trivially easy to do - replace the 3k3 into each of the clipping op-amps with (say) a 10k pot in series with a 1k resistor. You can then easily vary the "Drive" to each clipper.
  26. #26
    2,301
    Correct. Which is why I'm surprised it wasn't done originally. Not like it would have rendered the circuit dramatically more "complicated".
  1. Photo diode for clipping?
    By casey73 in forum Guitar Effects
    Last Post: 11-24-2009, 02:08 AM
  2. Marshall JCM diode clipping bypass mod
    By bluesbreaker18 in forum Mods & Tweeks
    Last Post: 09-24-2009, 12:02 PM
  3. Diode Clipping 2555SL Help
    By elduker in forum Maintenance, Troubleshooting & Repair
    Last Post: 03-26-2008, 05:00 PM
  4. Add diode clipping?
    By Lonzo in forum Theory & Design
    Last Post: 09-11-2006, 12:51 AM
  5. champ/princeton alternatives
    By scole in forum Theory & Design
    Last Post: 08-22-2006, 08:52 PM
