Results 1 to 4 of 4
Thread: speaker 8ohm help
    Nov 2009
    2
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    speaker 8ohm help
    Hi all,
    I have an 8 ohm speaker and I'm trying to figure out how to make it work!
    I tried to plug it into a simple amp circuit that produce a 0.1V as output on the speaker end. unfortunately...it doesn't work!
    any suggestion? I thought that an 8ohm 0.1W speaker was perfect....I'm quite sure there's something that Im completely missing here!
    thanks!
    0 Not allowed! Not allowed!
    May 2008
    1
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Try a battery to hear a "plop" sound. If not, the speaker is dead
    Nov 2009
    2
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    thanks carlitz but the speaker works! any other suggestion?
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    29,916
    Thumbs Up/Down
    Received: 90/1
    Given: 0/0
    The question is, what is the circuit you are using to try and drive the speaker?
    WHich is it, .1v or .1w?
  1. very old amp w/non PM speaker. Customer wants PM speaker installed.
    By tim in forum Maintenance, Troubleshooting & Repair
    Last Post: 12-03-2009, 02:29 PM
  2. 13ohm speaker load: 16 or 8ohm tap?
    By EETStudent in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-13-2008, 02:01 PM
  3. Dynamic Speaker to Permanent Speaker
    By alphamarquis in forum Debugging Your Build
    Last Post: 01-05-2008, 02:03 PM
  4. Getting a 16 Ohm Speaker down to 8ohm
    By greg in forum Theory & Design
    Last Post: 09-28-2006, 09:00 PM
  5. Need some speaker help!
    By Craig in forum Music Electronics
    Last Post: 08-23-2006, 07:57 PM
