A mismatched OT (either half or double the rated speaker load) won't normally cause unwanted noise, you may experience slight drop in power compared to a matched load.
More likely culprits are the tubes & power supply caps. You say that the amp has been serviced, are the power supply caps original '71 (metal can soldered to the chassis)? If so, they could do with changing.
LinkBack URL
About LinkBacks
