Results 1 to 24 of 24
Thread: More crunch?
    Dec 2009
    canada
    471
    More crunch?
    Hey guys,
    Can anyone here tell me how to get more crunch out of my 5e3? Do I decrease the value of the cathode resistor and increase the value of the plate resister in the preamp stage? I'm pretty new to this,and this is my first PTP build.I just want to get more crunch by using my guitar volume going from clean to dirty.
    Chuck.
    May 2007
    pacific north west
    13,031
    Are you saying the distortion you have isn't "crunchy" enough in nature? Or are you saying you want more overdrive/distortion? Or both?
    Chuck
    Dec 2009
    canada
    471
    Hey chuck ,thanks for the reply.I want more overdrive/distortion. Can't seem to get it to break up enough without having everything almost cranked.I would like to get some good overdrive without having to dime it.I hope this makes sense?
    Chuck.
    May 2007
    pacific north west
    13,031
    Quote Originally Posted by chuckb View Post
    That's because the power tubes don't start to overdrive enough prior to that.
    I think I understand. But what is the goal??? Do you want the amp to make more distortion at a lower volume? At this point it's worth noting that once your amp is starting to clip (overdrive/distort) the volume won't increase appreciably as you turn it up. It will just become more distorted. So if your getting some crunch at, say, five on the volume control, the distortion at eight or even ten will be much greater but the volume should not increase noticably.
    Most of the 5E3's overdrive is in the phase inverter and power tubes. To get more distortion at a lower volume you would need an attenuator. But this will reduce your clean tone volume when turning down your guitar's volume knob. A stacked gainstage and a master volume would also give you more distortion at a lower volume. But it won't sound at all like a 5E3, and without "channel switching" you will still be limited on clean headroom by using a master volume too.
    This is just the nature of the equipement.
    Chuck
    Dec 2009
    canada
    471
    Hey Chuck, Thanks for the input to my questions. I will leave my amp as it is now because I don't want to sacrifice the tone of the 5e3. I love that sound of overdriven tubes. I once used alot of overdrive/distortion pedals in the past, but once I heard the sound of a naturally overdriven amp I was hooked. IMHO, there is no pedal that can give that can give you that pure tone. My friend says I'm spoiled now because I have that tone in my head and that no pedal can replicate that. I believe that to be very true. Thanks again.
    Chuck.
    May 2007
    pacific north west
    13,031
    You could still build an atennuator for quieter practicing. I outlined an affordable one here:
    how to reduce power in a deluxe reverb
    If your using a 12ay7 in V1 you can swap that for a 12ax7 for more gain. If you stll want more overdrive it requires mods that would change your amp to something other than a 5E3. Aclean boost pedal in front of the amp can also add more dirt and won't sound like a stomp box.
    Chuck
  7. #7
    Jun 2006
    3,315
    You could try splitting the cathodes at V1 give one channel 1K to 1.2K, the cleaner channel 1.5K, each resistor will need a bypass cap. I'd put the lower value on the Normal/Mic channel as the Bright/Inst channel naturally has better fidelity. You'll still most likely need to turn the Normal channel way up.
    A channel switcher/ABY box is a better way to go from dirty to clean.
    You are happy that the amp is workig as intended in the first place?
  8. #8
    Dec 2009
    canada
    471
    Hey Chuck,yes, I would like more overdrive,can you suggest a mod. I already have a 12ax7 in V1 now.
    Chuck.
  9. #9
    HTH
    HTH is offline
    Senior Member HTH's Avatar
    Sep 2006
    Newcastle (UK)
    481
    Chuck.
    220k plate resistors on the first gain stage will give you more gain.
    Alternatively (or additionally depending on how much more gain you want), you'd get much more gain by cascading the two channels...
    This is just a starting point, you'd want to split the cathodes on the first tube (1k5/10uF on each is a good place to start)
    HTH - Heavier Than Hell
  10. #10
    Dec 2009
    canada
    471
    Thanks HTH for the info. I'll give your advice a go and see what kind of results I get. I'll let you know how it works out.
    Chuck.
  11. #11
    May 2007
    pacific north west
    13,031
    I just came up with this. To stack the channels you just plug into the "mic" channel and throw the switch. It allows you to have a stock amp or stack the channels and it's just simple as hell. This one places the tonestack later in the preamp (good). The only rub is that you can't use multiple inputs on the amp when the mod is switched in. Well, you probably could, but the results may be less than satisfying. However, if you do it this way you can still "jumper the channels" or use an A/B pedal for either channel with the mod switched off. So it's just like the stock amp until you throw the switch which could be located in the "low gain" hole of the "mic" channel so no extra holes need to be drilled.
    Chuck
  12. #12
    Senior Member ThermionicScott's Avatar
    Dec 2009
    SW CR IA US NA PE
    616
    In addition to bumping up those plate resistors, you could try "mis-biasing" the second gain stage so that it will clip sooner. Merlin's book has some good info on this. (One example is a Soldano gain stage that uses a 39k cathode resistor instead of the usual 1.5k)
    - Scott
  13. #13
    Senior Hollow State Tech Bruce / Mission Amps's Avatar
    Denver, Colorado
    3,045
    Quote Originally Posted by Chuck H View Post
    Chuck
    Have you tried this yet? I have not.
    Since the two triodes share the same cathode biasing resistor, and they will now be 180 degrees out of phase with each other, I wonder what the consequences will be....? You might get better results if you split the two cathodes and let them have their own biasing resistor and bypass cap.
    ChuckB
    Most good 12AY7 triodes in this circuit will make about 2.5vac to +3vac output... yes some stock tubes are hotter.
    The next stage (and only other gain stage, the 12AX7 volume pot recovery amp), will output around 22-24vac before distorting the PI.
    But even with a cleanish max volume level output, it is still usually more then enough over drive, saturate and or clip the cathode biased power tubes.
    If you want just a little more preamp gain.... remove the 22K B+ dropping resistor from the B+ rail (between the last to filter caps) and use a 5K@1w to 10K@1w resistor instead.
    Then use a 130K to 150K plate load resistor on the bright channel but reduce the coupling cap down to .047uF.
    Bruce
    Mission Amps
    Denver, CO. 80022
    www.missionamps.com
    303-955-2412
  14. #14
    May 2007
    pacific north west
    13,031
    Quote Originally Posted by Bruce / Mission Amps View Post
    Bruce, I haven't tried this. Hence the "I just came up with this". But it should work. And I did seperate the V1 cathode circuits in the diagram. There is no volume control for the stacked channel. instead it's attenuated by the parallel 68k input/grid resistors on the instrument channel for a load of 34k. If you look at the diagram you'll see that it's a REAL simple mod, and not very refined as there would probably be some wierdness if you switched in the mod and tried to run both inout jacks simultaneously or on an A/B pedal. So in that respect it's not really useable as a factory mod type thing. But you can use the amp as stock with the mod switched out. With the mod in your options would be to plug into the instrument channel and use it as normal OR plug into the mic channel for a boosted input signal to the instrument channel. Still, it's so simple that I thought someone may find it useful.
    I don't own a 5E3 so I'd love it if you (or someone else with a 5E3) tried it and report on how it goes. Maybe refine it?
    Chuck
  15. #15
    Denver, Colorado
    3,045
    Chuck
    oops... sorry Chuck, I didn't notice the split Ks in the artwork.
    I was fighting the onset of a blinding migraine headache this morning and was killing time waiting for the numbing drugs to take effect!
    I have couple 5E3 amps I'm building over the holiday week and I might give it a go if it doesn't take too long to implement and reverse.
    Bruce
    Mission Amps
    Denver, CO. 80022
    www.missionamps.com
    303-955-2412
  16. #16
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    10,051
    Hi Chuck, *killer* mod.
    A real "Dr Jekyll-Mr Hyde" switch, and as simple as can be.
    I love simple and elegant solutions , and this is certainly one of them.
  17. #17
    207
    It's the speaker/output tubes/power supply sound we're hearing that makes me build these tube amps.
    Voicing the preamp and using lower gain V1 is recommended to try [12a_7, anything except an 12ax7], distortion from the preamp is semi-futile [when I play too low for the ''speaker/tubes sound''], something else makes the distortion for that.
    Lower effeciency speaker, but I don't mess with that either, I like 'em effecient so have little experience and envision a difficult time finding a 'queit' speaker that breaks up/has same basic tone as my 'standards' {GB's Blue, TT's} speakers.
    Along with the sweet tone of the tube/speaker relationship @volume, you'll notice a more strict relationship between volume and tone changes than say a bigger cleaner [higher wattage] tube output/speakers to handle it, relying on distortion provided by preamp or pedal. Pretty much directly relates volume and distortion, especially plugging the pickup to the amp input.
    However, trying out 6k6 output tubes would be most interesting in the ''drops volume without changing tone'' dept. [a misnomer].
    If I was having 6k6's here, I'd be trying that out.
  18. #18
    Phoenix
    689
    You could just put a clean boost pedal in front of the amp. The Duncan pickup booster is cheap and works well for this application.
  19. #19
    daz
    daz is offline
    Old Timer daz's Avatar
    Jan 2007
    2,547
    To expand upon that idea in a way that would make it more controllable volume wise, he could use a clean boost in front and add a simple master volume at the PI. this way he could hit the preamp hard enough to get anywhere from a ton of drive to just a bit from the pre and get it at any volume. Now of course thats not going to sound the same as the 6V6's cranking, but if he wants grind at lower volume this will give it to him at most any volume. plus he can turn the master up to a point just where the 6V6's are partially distorting then adjust the clean boost to add just the right amount and get a blend of pre and power amp grind and in that way also find different colors he may like too. It's like total adjustability with a simple one pot mod and a clean boost pedal. I' have used that in the past on many amps with some very good success. And a clean boost i find can actually be a better sounding way to OD preamp tubes than cascading them.
  20. #20
    Aug 2008
    51
    Chuck
    I was looking at this and liked it but was a little worried at the 33k to ground as I contemplted its use for an amp I'm building. Eventually I figured you could use a DPDT switch and use the other half to switch out the ground connection in the Hi input and run it across a pot or trimmer. So basically the junction of the 33k ( the joins of the two 68k's to ground) gets lifted when the switch is thrown and a fixed or adjustable resistance goes accross the outer lugs so normally it's all grounded as usual and switch thrown. A drawings better eh?
  21. #21
    May 2007
    pacific north west
    13,031
    Quote Originally Posted by sean k View Post
    Yes... But I get it. And it's a good idea. The only rub is that the load is the bias resistor. If you switch it out your going to leave the grid of that stage floating for a moment. I don't think it would hurt the tube but it will almost certainly make a loud "POP" when the switch is flipped. The onlt way to avoid the POP would be to hang another load resistor ahead of the switch... And now it's getting complicated with the DPDT and the extra circuit changes. My point to this was that it's really simple.
    Chuck
  22. #22
    Aug 2008
    51
    Yeah Chuck, the original is simple and efficient but as always I'm using i for something I'm doing so I've added things to make it a little more to my taste and I'm glad you bought up the pop. A 2.2M from the bottom tubes cap, centre lug on right side of switch,accross to the bottom lug of the other side of the switch should take care of that... or do you mean the new cap that goes to the top tubes grid... won't that then have the 1M to ground on the input to shift the charge.
  23. #23
    May 2007
    pacific north west
    13,031
    AAAhh. I got ya now. Good idea. I thought you meant to switch the load to a dedicated circuit apart from the two 68k's. That would certainly POP. But your idea simply parallels them with a pot. In your drawing the normal 1M input load resistor keeps bias on the tube so the act of switching won't float the grid of that triode. Should work great. If it does pop it probably won't be so bad as to be annoying.
    Chuck
  24. #24
    Aug 2006
    26
    My fave mod for the 5E3 is:
    -12AX7 preamp tube
    -Split cathodes on input/1st tube. Make the "bright" side 2.7k/.68 (yes, like a Marshall) the "normal" side 1.5k/10uf (sorta like a Fender.)
    -.02 coupling caps in the preamp, down from .1
    Makes it behave w/humbuckers, still acts like a 5E3, fairly crunchy when cranked and any little p.o.s. o/d pedal sends it straight to VanHalen/ZZ Top-land.
    Hope ya dig it.
    Ace!8-)>
    Ace Pepper Custom Amps
  1. tsl60 no sound from crunch or lead chanels
    By bennieusmaximus in forum Guitar Amps
    Last Post: 01-15-2009, 02:21 AM
  2. marshall lead 12 3005 no crunch
    By jologman2000 in forum Maintenance, Troubleshooting & Repair
    Last Post: 06-07-2008, 02:59 PM
  3. Peavey Ultra Plus - crunch mod
    By Twangmaster in forum Maintenance, Troubleshooting & Repair
    Last Post: 11-27-2007, 08:46 AM
  4. H&K Triamp Crunch Channel
    By Gregg in forum Theory & Design
    Last Post: 06-20-2007, 01:45 AM
  5. Peavey ULTRA PLUS crunch sw problem
    By Amptek in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-23-2006, 06:28 PM
