+ Reply to Thread
Results 1 to 8 of 8
Thread: Electromuse A55 in dire need of repair
    Member Resonator Guy's Avatar
    Jan 2009
    Prince Edward County Ontario Canada
    81
    I recently purchased an Electromuse A55 chassis, made by Valco, on ebay. I knew it wouldn't work but thought it would be a fun project as it has a 6SJ7, 6V6, 5Y3 lineup just like early Champs. I haven't recapped it yet and it badly needs that but I replaced a few obviously blown caps and resistors, put on a 3 prong cord to replace the cut off one and it actually works, a little.
    I am making up my parts list and a couple of items have me stumped. In previous years, someone else has obviously "fixed" this and I am working without a schematic.
    There are two items below, resistors of some kind I trust, that I have never seen before so I can't determine their values.
    Attached are some pics. The lozenge shaped ones have 6 colours on dots on them, and the long cylindrical one seems to have two colours in bands. Since the layout doesn't really correspond to a Champ, I can't even make educated guesses as to their values.
    Can anyone assist?
    Attached Thumbnails Attached Thumbnails 100_1614.jpg   100_1617.jpg   100_1619.jpg   100_1620.jpg
    Senior Member Jazz P Bass's Avatar
    Dec 2008
    Wernersville, PA
    877
    Capacitor code
    The little guys with the dots are capacitors.
    Can't tell on the banded one. Probably a cap.
    My advise to you, would be to sit down & draw the circuit.
    It may take a while & a few iterations, but it will be well worth the effort.
    I would start with an amp layout & then draw the schematic.
    After you are finished the amp will reveal what it was designed to do.
    Then you can tweak & mod.
    Jan 2009
    81
    Thanks JPB. I have over twenty amps that I have recapped etc but had never seen stuff like this before. Based on your advice, I checked out some sites and indeed those are molded mica caps and the long one is a molded round paper cap. There is even a molded flat paper cap hidden under the mica ones. Now I know how to read the values, I will continue the rebuild. I will take a shot at drawing out a wiring diagram and schematic as well.
    The thing operates at about 1/20th power right now and I am sure the filter cap can is original, so I will replace all the caps before I try anything else.
    Jan 2009
    81
    Last post for this one. I will start a new thread if I run into trouble. The long one is not a round molded paper cap, it is an old dog-bone resistor. I am ready to go with the filter cap can now, but it looks ordinary.
    Apr 2009
    291
    Quote Originally Posted by Resonator Guy View Post
    If it's down on volume I'd start looking at those resistors for drifted values. They're notorious for that.
    Phoenix
    491
    It may be working fine but with the speaker cone seized up. Check with another speaker to make sure. If all else fails, you can reference an early Champ with a 6SJ7 pre-amp.
    http://www.schematicheaven.com/fende..._5c1_schem.pdf
  7. #7
    Jan 2009
    81
    Thanks guys.
    It isn't a speaker problem as I got only the chassis. I am testing with (I hope) a good speaker. I have ordered the parts I know I need so far and after checking Champ schematics, it is a fair bit different. For instance a four part cap can (4x10uf) rather than 3x10uf for the champ. I ordered a 4x20uf can that might get here before Xmas. After that is in I will check all the resistors and see where it goes.
    It is all fun. I might get frustrated if I was doing this for some one else, but it is just a great hobby.
  8. #8
    Jan 2009
    81
    Electromuse A55 just waiting for a cabinet now.
    I finally replaced every cap and every resistor in this chassis. I always have to wait a while for parts as I don't want a five or six hour drive to get to an electronics store, so I order just about all my parts from AES, one amp at a time.
    It isn't a terribly loud amp but it sounds really good. I have run it through several speakers and have settled on a Teisco Checkmate 28 speaker cab that I already have. That seems to work well, so I will build a head cab to sit on top.
    With a 5Y3, the 6V6 was only drawing 37.1 ma, but with a 5V4 it is drawing 42.5, so I believe that will be alright, assuming my meter is anywhere near accurate. The big bottles also look pretty cool in it.
    Thanks for all the assistance. On to the next one!
+ Reply to Thread
  1. When to start repair.
    By j.d.roost in forum Maintenance, Troubleshooting & Repair
    Last Post: 10-17-2009, 05:31 AM
  2. Optical pedal repair
    By Rhodesplyr in forum Maintenance, Troubleshooting & Repair
    Last Post: 10-07-2009, 01:49 PM
  3. motherboard repair
    By jarvis1227 in forum Fun with computers
    Last Post: 06-19-2009, 03:41 AM
  4. repair checklist
    By antiunderscores in forum Maintenance, Troubleshooting & Repair
    Last Post: 11-11-2008, 06:52 AM
  5. Repair Safety First
    By mykey in forum Maintenance, Troubleshooting & Repair
    Last Post: 12-27-2007, 06:19 AM
