+ Reply to Thread
Results 1 to 4 of 4
Thread: Super Reverb SF correct filter resistor values?
    Dec 2009
    Sweden
    2
    Hi,
    This is my first post to this very knowlegeable forum.
    I'm about to replace the filter caps in my -74 SF, and at the same time
    replace the 'dropping resistors' next to the large capacitors. I have studied
    the available schematics which all say 4.7k and 1k for these resistors.
    When I look what's in the amp they are 10k and 2,2k. See attached photo.
    My amp is an export 220v model, and seems to be completely stock.
    What puzzles me is, when I check my other SR (a -66 Blackface) it has the 4.7k and 1k resistors. This amp had the caps replaced before I got it.The BF is also a 220v amp.
    Why the difference? What values should I use for replacement?
    /Jan Torstensson
    Sweden
    May 2007
    pacific north west
    1,892
    Quote Originally Posted by Torstensson View Post
    I have studied the available schematics which all say 4.7k and 1k for these resistors. When I look what's in the amp they are 10k and 2,2k. See attached photo. My amp is an export 220v model, and seems to be completely stock.
    The '74 schem I found indicates 2.2k and 10k are the correct values.
    Why the difference?
    Different amp. Different designer with different preferences about how to operate the tubes.
    Do you like the way this amp sounds? If you do then use the values that are in there.
    Chuck
    Dec 2009
    Sweden
    2
    [QUOTE=Chuck H;135966]The '74 schem I found indicates 2.2k and 10k are the correct values.
    Ok, thanks alot Chuck, smoke cleared. Do you have a pointer handy
    for the correct schem? I only found the BF version or SR master vol.
    /Janne
    Sep 2007
    97
    Quote Originally Posted by Chuck H View Post
    Chuck
    Where did you find the schematic with those dog house values for a 74'???
+ Reply to Thread
  1. SF Twin Reverb Distortion - Filter Caps???
    By mikeboone in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-12-2009, 06:09 PM
  2. crackling sound on my SF super reverb
    By qwixzh in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-01-2009, 11:45 AM
  3. filter cap values
    By cminor9 in forum Theory & Design
    Last Post: 11-18-2008, 12:15 AM
  4. BF Super Twin Reverb - Burnt resistor
    By cjlectronics in forum Maintenance, Troubleshooting & Repair
    Last Post: 10-16-2008, 03:08 AM
  5. Filter Cap Values?
    By michaelj in forum Maintenance, Troubleshooting & Repair
    Last Post: 07-13-2008, 06:43 AM
