Results 1 to 5 of 5
Thread: Ampeg VL-503 not working tube arent glowing
    Oct 2009
    10
    I just got this VL-503, the thing worked when I checked it out, but when I got it a home and cleaned it up pots and so forth. When I got it back together Its not working. There is no sound and not a one of the tubes are glowing. I will admit that I hit one of the power tube with a screw driver on accident, do you think that this could be the problem? Can a tube go bad so that it wouldn't emit light? and If one power tube isn't working would the other not light as well, or should I look else were? I'm about 85% sure that I got every thing back in the right spot, This isn't my first rodeo. I'm lead to believe that the tube where in need of changing to begin with. any ideas would help.
    Oct 2009
    10
    Well I figured it out there was a loose wire from the tranny.
    Senior Member Guitarist's Avatar
    Jul 2006
    488
    Very nice amp! Some of them had an issue with the filament wiring getting hot and melting the molex connector. Clean or solder on perhaps. I just shaved off the last two or four wires from the rest. I've did some serious mods to the VL102, or whatever it was called.
    Did I say killer amp!
    Oct 2009
    10
    I have fell in love, Now that its working. By far one of the best sounding amplifiers I have owned to date. What where the mods you did. If anyone else has any mods or a schematic that would be real cool.
    Jul 2006
    488
    N.B. This applied to the the VL- 502 and good tonal gains were realized, according to my taste. Still, doing this to my amp, well designed and constructed it really is, made me a believer in point-to-point.
    Approach: move gain/volume downstream and defrag front-end; Improve clean tone
    1) Swap both volume pots of clean channel preamp away from 1M < -- > Master 250K
    2) Move C3 to now parallel r9 of V2a (worry not, tone sections still moves mucho bass). Cap can be decreased to 5uF
    3) Increase sizes of clean caps C2 (interrupt trace) and C7 to .047
    4) Remove R11
    5) Increase R5 to 220K
    6) Try a feedback circuit 40M in series with a big cap such as .1 from plate to grid of stage 2/V1b. Optional
    7) Parallel R10 with a 150K resistor. This is to optimize the tone of the lower mu triode. Optional
    8) Change V2 to a 12DW7 (dirty channel's triode/half still high mu) or a 12aT7 etc.
    9) Parallel C1 with a 1uF. (This will fatten up the heavy channel as well)
    10) Increase trebel tone cap to 500pF. Optional.
  1. Ampeg VL-503 Blowing Fuses
    By pastorking in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-25-2010, 03:53 PM
  2. Ampeg VL-503 schematic
    By TD_Madden in forum Maintenance, Troubleshooting & Repair
    Last Post: 11-11-2008, 12:37 AM
  3. Ampeg vl-502 tube socket short?/fire
    By davis1866 in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-28-2008, 09:49 PM
  4. Ampeg VL-1002/Please help..
    By 5150 TONE in forum Maintenance, Troubleshooting & Repair
    Last Post: 05-24-2007, 05:42 AM
  5. Peavey Classic 30 tube glowing red
    By rrrip in forum Maintenance, Troubleshooting & Repair
    Last Post: 04-29-2007, 05:39 AM
