| Music Electronics General discussion about music electronics |
| | #1 |
| Junior Member Join Date: Jan 2010
OK EVERYBODY, SO I AM A NOOB IN DIY ELECTRONICS BUT NOT SO DUMB ON TERMINOLOGY. SO HERES MY THING I HAVE A PEDALBOARD AND WANNA RUN TWO DIFFERENT DISTORTIONS IN PARALLEL WITH EACH OTHER. I NEED TO BUILD 2 PASSIVE BOXES FOR THIS PROJECT AND NEED HELP DOING SO... I WILL RUN MY GUITAR INTO MY BOSS TUNER WHICH IS BUFFERED SO MY IMPEDANCE FROM MY GUITAR SHOULD NOT BE AN ISSUE. I NEED TO SPLIT THE SIGNAL, WHICH I AM AWARE CUTS THE SIGNAL AROUND 6db AND THATS OK.... AND I NEED TO BUILD A BOX THAT DOES THE EXACT OPPOSITE AND JOINS TWO MONO SIGNALS INTO SINGLE MONO OUTPUT TO RUN THROUGH MY OTHER STOMPBOXES. SO HERES THE CHAIN, CAN YOU HELP ME FILL THE QUESTION MARKS? the ones in ">>(...)" are the parallel bottom signal guitar>boss tuner>SPLIT BOX>mxr zw-44>>(v.s. jekyll and hyde)> boss ds-1>> digitech hardwire valve distortion>>>JOINER BOX> crybaby wah> Boss EQ>>> etc.. etc... SO MY SIGNAL CHAIN STARTS AND ENDS WITH BOSS BUFFERED PEDALS. SO I SHOULD BE OKAY WITH THE 6 dB cut. CAN SOMEONE PLEASE JUST TELL ME AN EASY WAY TO WIRE UP THESE BOXES PASSIVELY? |
| | #2 | |||||
| Lifetime Member Join Date: May 2006
Hi, Tim. Look at the left side of your keyboard. There's a key there marked "Caps Lock". Try pressing that a time or so until the all-caps you're typing reverts to normal case. It will sure help us help you. Many people find all-caps very irritating. Quote:
Quote:
Quote:
Quote:
Can you try that again, with one line for guitar up to split box, second line with top chain before join box, and third line for bottom chain before join box, then fourth line for after join box? Quote:
Do go look over your keyboard for that Caps Lock key, would you? | |||||
| | #3 | |
| ok ill try again lol Quote:
ok so here is my signal chain guitar-> boss tuner-> SPLIT BOX-> -->(output one from splitter)-->Visual Sound Jekyll and Hyde--> mxr zw-44 --->(output two from splitter)---> Boss DS-1---> Digitech hardwire valve dist. chain 1--> JOINER BOX----> crybaby wah-> boss eq-> morely volume-> boss delay-> AMP chain 2---> JOINER BOX----> ( joined to same as above) so let me get this straight, to SPLIT the signal i should go from my tuner to the input of the splitter. solder 2 wires together from the tip of the input and run them each to a 10k resistor THEN to the tips of the two output jacks. and to join them together i just basically flip the circuit around? do i just connect the grounds together? | |
| | #4 | |||
| Quote:
If your tuner does have a buffer in it, then you can simply use a hard-wired Y cable. The low impedance of the buffer in the tuner and the high impedance of the DS1 and the J&H will prevent them from loading down the tuner, and they will work as normal, no significant losses. This is NOT true if the tuner is not buffered. That's more complex. Quote:
Quote:
| | #5 |
THANKS !!! that helps alot. now you said an active splitter would work better. how difficult is it to make an active splitter? can you send me the pcb layout or something for an active splitting circuit?
| | #6 | |
| Quote:
The key factor is that your tuner is buffered; the buffered output can drive more than one input, especially more than one high impedance inputs like you have. An active splitter in this would add complexity but no performance. | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| DIY Head Box Question | Kramer | Cabinetry | 3 | 08-16-2009 12:44 AM |
| simple footswitch help | czech-one-2 | Guitar Effects | 4 | 04-05-2008 09:34 AM |
| two simple questions | Joe Bee | Theory & Design | 0 | 11-29-2007 06:43 PM |
| simple preamps | Tim Hall | Theory & Design | 5 | 11-27-2007 01:53 AM |
| Noise Reduction DIY >not gated< DIY? | orson | Guitar Tech | 8 | 06-28-2006 10:59 PM |
