| | #1 |
| Junior Member Join Date: May 2009
| Help locating Squier Affinity 5 way switch
Can someone point me in the direction of a replacement 5 way switch for a Squire Affinity Strat ?? I used a Strat kit from StewMac only to find the actual reason 2 different switches are utilized. It won't fit cavity due to narrow body. I'm going to leave the pots and cap in place & just change out the 5 way so it should be simple. I just don't want to get the wrong switch (again) Thank You, |
| | #2 |
| Senior Member Join Date: Dec 2008 Location: Wernersville, PA
| 5 way switch
Did you try Fender Support?
| | #3 |
I have been to both the Squire & Fender sites and saw no provisions to order parts, The best I can tell is the part # is 0055412000 Switch, 5 Way Shallow Box Style. Did a lot of searching and came up with little. |
| | #4 |
| Pickup Maker Join Date: May 2006 Location: Montclair, NJ
They have some of the box style here: Guitar Parts Resource* ::* Lever Switches Here's another compact style: 5-Way Lever Switch And some more here: Switches by GPDUSA.COM I'm not sure if they are the right size, but you can compare the original to these.
__________________ Those who create are rare; those who cannot are numerous. Therefore, the latter are stronger. - Coco Chanel www.sgd-lutherie.com www.myspace.com/sgdlutherie www.myspace.com/davidschwab |
| | #5 |
Thank You, I ordered 2 different 5 ways from GPD, one looks like the original switch that was in the 3rd party pickguard that is on guitar currently. I also ordered the sealed 5 way switch. If they are the same dimensions I will give the sealed one to my friend for his HSS Squire, he may need one in the future. |
| | #6 |
| Junior Member Join Date: Jan 2010 Location: Poland
Tell me something, because I'm the owner of Squier Affinity Strat by Fender for 7 years, and there's something wrong with this pickup switch. One guy who seems to be kinda into this stuff, told me that this is very common thing, taht after few years those switches stop working properly. I mean on the bridge and neck positions (so outtermost) the guitar switches off. Why is it so? Do I have to buy new switch or can I do somenthing with the old one? |
| | #7 |
If you slightly move the switch (staying in the current selection) while it is producing no sound in either of those 2 positions does it try to work or make any sound when moving ?? The reason I replaced this switch was due to intermittent no sound in the (front) neck only position. |
| | #8 |
It works exactly like You said! Slightly moves helps, but I can let I going that way. It's annoying. Why it happens like this? What can I do? I heard it's quite common...
| | #9 |
You may be able to clean with contact cleaner... which in this day and age can be hard to locate and some cc will melt plastics. The switches sell for $5 retail so you can't expect much & they get used a lot. These switches are only about 1" deep. |
| | #10 |
Thanks a lot (specialy for the plastic-melting note - it's inportant). So I have two options. I suppose using CC won't help much? What You think? It's better to change whole switch. But switches are different depending on model of the guitar. Mine is Squier Strat by Fender Affinity Series, so it looks like this: ![]() Does anybody knows the symbol of this one? Why does it happens like this? Is there a way to buy even more expensive one, but stay working properly longer? |
| | #12 |
What is the depth of that switch shown ?? The guitar i'm working with has a 3rd party pickguard and the switch does not look like that, it uses the "box type" switch. It also looks like a box switch on the service info from Fender. That looks similar to a standard strat switch. |
| | #13 | |
| Quote:
The ones I have from the 90's say Schaller on them, so that may be an OEM model, or an Asian copy. But any switch should work in this case. That's not an unusual size. Sometimes you have to install them with the circuit board on one side or the other.
__________________ Those who create are rare; those who cannot are numerous. Therefore, the latter are stronger. - Coco Chanel www.sgd-lutherie.com www.myspace.com/sgdlutherie www.myspace.com/davidschwab | |
| | #14 |
Make sure to measure your switch and use the mounting depth information. The box switches that I recieved were both 1 1/8" to the flat folded terminals. Pay close attention to your lead dress and solder connections. Even into the 1 3/8" cavity it was still a tight fit. The specs for StewMacs switches are 1 3/8" |
| | #15 |
So I can order no matter what kind of switch until it is short enought to fit? AAnd 5 positons of course. Am I right?
| | #16 |
Some of the special switches can be configured differently, others are fixed configuration. (N N/M M M/B B) like the box switches and the standard 5 way strat switch. The depth is critical on the Squires.
| | #17 |
| Senior Member Join Date: Oct 2006 Location: Toronto
I have never come across a switch being too big to fit in an affinity strat. the only time i have hit that problem is with the bullet model. hmmmmm |
| | #18 |
| What I find strange is the picture that was posted shows the non box style switch (1/2 circle type) and the Squire Affinity service data and the aftermarket pickguard assembly that was on it, use a box switch ( I never saw what was in the guitar originally) I don't know the depth of the switch in the picture. I also wondered why 2 styles of switches were used. My friend (who can play guitar) mentioned that the body was thinner on these models.
| | #19 |
I have never ever customized it. I'm the first owner. Maybe the difference is - if it was crafted in China or the USA? Unfortunatelly mine is crafted in China |
| | #20 | |
| Quote:
Your solder lugs are standing straight as well. Maybe a mini version of the standard strat switch ?? | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Locating loud hum/noise | EETStudent | Maintenance, Troubleshooting & Repair | 14 | 12-06-2009 01:43 AM |
| Locating Noise | EETStudent | Maintenance, Troubleshooting & Repair | 5 | 03-14-2009 05:28 AM |
| Expensive Squier | Sock Puppet | Lobby | 3 | 10-28-2007 11:18 AM |
| Locating Buzz in Distortion | Tim Hall | Maintenance, Troubleshooting & Repair | 5 | 05-29-2007 11:42 PM |
| Squier Sidekick noisy | rocket | Maintenance, Troubleshooting & Repair | 3 | 12-05-2006 08:37 AM |
