| Guitar Amps General discussion about amps |
| | #1 |
| Junior Member Join Date: Dec 2009
| crate vitage club 2110r tube location
I am fairly new with tube amps and have a crate vintage club 20.I need to know which tube is for the gain,reverb phase inverter. I have some schematics but the just say v1 v2 v3.Thanks for any help in advance.Have some nos tubes I want to try in the phase inverter.
| | #2 |
| Senior Member Join Date: Dec 2008 Location: Wernersville, PA
| Crate V20
The phase inverter typically is right next to the power tubes. The first input tube, V1 is the farthest from the power transformer. Can you post the schematic? |
| | #3 |
| | #4 |
| Crate VC 2110R
So much for typical. Are the tubes lined up in a straight line. (3) 12AX7s then (2) 6BQ5 output tubes? The preamp tubes are V1, V2 & V5. The output tubes are V3 & V4. Here is the signal chain: 12AX7 dual triode. Input to V1A to V1B to V2A to V5A & then the phase inverter is V2B. V5B is the reverb drive tube. |
| | #5 |
yes they are 3 12ax7 then 2 el84 i have some old hammond organ tubes 12ax7 from great britian and holland and 1 12au7 made in usa I heard the 12au7 would do well in the pi. thanks |
| | #6 |
The schematic doesn't tell you the tube order. Look on the layout for that. V numbers refer to positions on the schematic, they do not refer to tube order across the chassis. Sometimes they are the same, but often they are not - as is the case here.
| | #7 |
| Crate
Without having the amp in front of me I cannot tell you which tube is in what location. You would have to sit down with a meter & figure it out. What a goofy numbering arraingment. I think you may have an issue with trying out a different tube specifically for the phase inverter. It uses one half of V2. The other half, V2A, is linked to the tone control, mid boost & level set. V1A & V1B are the first stage & volume control. V2A: Tone & Level V2B: Phase Inverter V3 & V4: 6BQ5 output V5: Reverb |
| | #8 |
Jazz, dude, that is why I put up the layout pictorial just above you.
| | #9 |
Thanks guys so from what i read v1 gain/tone v2 pi v5 reverb in that order 123. would the 12au7 be a good choice for the pi.I used the hammond tube made in great brittian (mullard ?) in v1 and the 1 made in holland (amperex-phillips?) in v2 and v5,was reading that the 12au7 was a good tube for the pi position.the 1 I have says made in usa these are all out of a hammond e-1oo. |
| | #10 |
| Fast typing |
| | #11 |
I know, I checked the time stamp when I posted that. I was just banging on your cage.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| crate vintage club 2110r tube location | ecoman35 | Vintage Amps | 2 | 02-22-2010 04:59 PM |
| Help with Crate Vintage Club 50 | arjay | Maintenance, Troubleshooting & Repair | 14 | 08-31-2009 02:55 PM |
| Crate Vintage Club 50 VC5310 | timt | Maintenance, Troubleshooting & Repair | 21 | 06-30-2009 02:35 AM |
| Crate vc-2110r reverb mod? | GP1953 | Mods & Tweeks | 0 | 02-25-2009 05:15 AM |
| help with Crate Vintage Club 50 (schem) | JC@ | Maintenance, Troubleshooting & Repair | 5 | 10-23-2007 02:51 PM |
