Go Back   Music Electronics Forum > Amplification > Guitar Amps
Guitar Amps General discussion about amps
Old 02-07-2010, 04:51 AM   #1
Dickerson amplifier part 1930's-40's
I am working on a old Dickerson amp and found a piece I do not recognize. I would appreciate any help if you recognize it.
MstrB is offline   Reply With Quote
Old 02-07-2010, 06:59 AM   #2
That is the spark plug.
Where is it wired in the circuit? Looks like a very early point contact diode to me. I have seen them, but don;t recall specifically. My diode thought might be wrong.
__________________
Old 02-07-2010, 07:11 AM   #3
It is right off the input jack to the preamp triode grid. This is a very early amp with no power switch, tone or volume controls. Field coil speaker.
Old 02-07-2010, 08:24 AM   #4
Doesn't sound like a place for a diode then.
__________________
Old 02-07-2010, 02:01 PM   #5
JFC
Have you tested it with a meter?
JFC is offline   Reply With Quote
Old 02-07-2010, 08:37 PM   #6
I tested it and it appears open. That is why I neede to know what it was so I can replace it. I have never seen another Dickerson like this, nor have I found a schematic for it. 5Y3, 6V6, 6SQ7. The diodes in the 6SQ7 are not used.
Old 02-07-2010, 09:05 PM   #7
Jazz P Bass's Avatar
Unidentified Item
Input Capacitor?
Jazz P Bass is offline   Reply With Quote
Old 02-07-2010, 11:09 PM   #8
Google to the rescue...
Check this page out; it describes the mystery part:
The component was a rare battery bias cell used to apply a negative bias to the 6SF5 preamp tube.
Here's a link to an image of the cell in his Dickerson:
http://www.charlestonarea.com/Dickerson/BiasCell.jpg
And another reference page...
gmoon is offline   Reply With Quote
Old 02-08-2010, 07:59 AM   #9
Thanks! that is the part and the very same amplifier model. I will have to check the tubes but this is a great lead.
Old 02-08-2010, 09:31 AM   #10
Supporting Member
Steve Conner's Avatar
Well, I would honestly never have guessed. Maybe you could, shock horror, leave the battery out and just connect two diodes in the cathode circuit of the tube instead? It's 1.2V of bias either way.
Or I suppose a silver oxide button battery, the kind used in watches and old cameras would replace it.
Does yours have the mother-of-pearl finish? It's a beautiful looking cabinet.
Steve Conner is offline   Reply With Quote
Old 02-08-2010, 03:40 PM   #11
I *Loved* the
Quote:
cathode bias, or bias derived from the voltage drop in the negative lead of the power supply system, has many disadvantages.
bit.
Salesmen will cook up *anything* to make the customer feel insecure about what he already has, which can be easily be solved by buying their product, whatever it is.
Things do not change that much, after all.
J M Fahey is offline   Reply With Quote
Old 02-08-2010, 08:15 PM   #12
Quote:
It is a bias cell. They were used in a lot of Knight PA amps. You can revive them by injecting a bit of distilled water into them and sealing up the hole with a little silicone sealer.
Prairie Dawg is offline   Reply With Quote
Old 02-09-2010, 12:26 AM   #13
COOL. I love learning new stuff, even if it is older than I am.
And I love the "mother-of-plastic" finish on the cab.
(No offense to the AMI fans)
__________________
Old 02-09-2010, 05:24 PM   #14
I was puzzled the first time I encountered one, but lucky me some nice person gave me the first thirty volumes of Photofacts bound. The cells did come back nicely after being treated with a little juice. I guess any way you can get a negative voltage is a good way.
Old 02-10-2010, 01:28 PM   #15
Coitainly--and like Steve suggested, you could try replacing it with a button cell.
I also love the MOTS cabinet! Gotta wonder if there's a matching lap steel floating around somewhere...
ID this part ? Valvehead Maintenance, Troubleshooting & Repair 3 01-21-2010 04:37 AM
part values Valvehead Maintenance, Troubleshooting & Repair 5 05-19-2009 02:46 AM
This 40's [?] Organ Has Many a Tube, and petemoore Conversions 2 04-09-2009 10:43 PM
Help identify a part please! PurpleStrat Conversions 3 08-30-2008 08:24 PM
lathe help part two... Possum Pickup Makers 20 10-13-2007 06:39 PM
