Old 02-09-2010, 03:36 AM   #1
My Classic 30 DIED!!!
Hi Everyone!
Well, here's the deal...a couple weeks ago I was playing at church on my Classic 30. I left my amp sitting for a few minutes before the service started and when I got back to play, it didn't work anymore!!! I wasn't sure what was going on because the the power/pilot light was still on but nothing was coming out. I checked the tubes and none of them were lit up so I knew it wasn't a quick fix.
I was finally able to check it, I found that the P.T. and all the tubes were not heating up in the slightest. I found this odd because they're normally pretty hot!
I checked the fuses and they all still had continuity so I'm assuming they're fine. I checked power going into the P.T. and it read about 117 volts (normal), but when I checked the other side of the P.T. at the fuses, I was only able to get a 3-5ma reading on one of the wire sets. My thought is that the P.T. is blown, but I'm no expert which has led me here...to ask some experts.
Anyway, I would really appreciate any input you guys have...
Thanks for the help!
greentexasbandit is offline   Reply With Quote
Old 02-09-2010, 04:40 AM   #2
Supporting Member
Quote:
Originally Posted by greentexasbandit View Post
I'm just at a loss right now as to what comes next.
a trip to your tech. Those c30s are a dog to work on
__________________
Old 02-09-2010, 07:49 AM   #3
Did you actually REMOVE each fuse and measure it with an ohm meter while it was out of its clip? Your 10A heater fuse will seem to measure OK while it sits in its clip. Otherwise, we might check those couple 3w resistors in the heater string.
__________________
Old 02-09-2010, 07:57 AM   #4
hi
Look at the wire between the two cards (near the power capacitors) in your classic 30. they would be broken ...
Regards
Denis
ermynn is offline   Reply With Quote
Old 02-09-2010, 08:33 PM   #5
Yes, I removed all fuses from their clips and measured them with an ohm meter...they all kept their continuity while they were out of the clips. I also took out all of the tubes and checked them as well.
Old 02-09-2010, 08:34 PM   #6
I'll take a look at the wires between the cards...haven't checked those too closely yet. Thanks
Old 02-09-2010, 10:00 PM   #7
Isn't it possible that one (power) tube filament just failed open circuit? Since they are wired in series, it only takes one 'open' to the kill the set.
Try replacing the power output tubes (one at a time) with a known good one.
Gunny is offline   Reply With Quote
Old 02-09-2010, 10:08 PM   #8
Hmmm...I tried changing them out in pairs because I still have the factory tubes, but didn't get anything out of it. I guess I should try one at a time though.
Old 02-10-2010, 12:35 AM   #9
Pretty darned unlikely that more than one heater is oopen, but it takes only seconds to check.
If the heaters do not light and the heater fuse is good, then you have a continuity problem. Either a broken jumper link, or an open series resistor. R71,72 are 3 ohm 5w, on the end of the center board near the fuses.
__________________
Classic 30 help Marshall_Super_100 Maintenance, Troubleshooting & Repair 10 03-04-2009 10:00 AM
New Approach to a Classic 30 randomhitz Mods & Tweeks 12 03-03-2009 02:22 PM
peavey classic 30 Ron S ANDERSON Maintenance, Troubleshooting & Repair 8 01-19-2009 05:17 PM
Peavey Classic 30 peavey Maintenance, Troubleshooting & Repair 1 04-12-2008 02:41 AM
Peavey Classic 30 same as always?? PlayItAll Mods & Tweeks 2 02-16-2008 04:05 PM
