+ Reply to Thread
Results 1 to 4 of 4
Thread: Yamaha T100C
    Jan 2009
    Santa Cruz, Calif.
    76
    Yamaha T100C
    I am posting some pictures this time and hope they will help solve the mystery.
    Problem... amp plays only with very low volume and has a lot of distortion.
    All advice appreciated.
    Doc
    Attached Thumbnails Attached Thumbnails 02080002.jpg   02080001.jpg   02080001a.jpg
    Lansing, Michigan, USA
    11,707
    Pictures don;t tell me much.
    What voltages are going on in the power amp? HAve you plugged a signal into the power amp in jack or the FX return jack? Have you sent the preamp signal from either the FX send or the preamp out jack to some other amp for a listen?
    HAve you substituted known good tubes into the amp?
    Have you tried more than one speaker cab?
    Member JerryP's Avatar
    Jul 2006
    Syracuse, NY
    64
    I've seen several of these amps come thru here with a failed resistor near that 47 uf cap on the main board. If I remember right that was the symptoms they had too. Check the resistors around that tube on the back corner of the board near the power supply board to see if any are open.
    Jerry
    Jan 2009
    Santa Cruz, Calif.
    76
    Yamaha T100C
    Hey Enzo and Jerry....Thanks for your help. Found/fixed problem : bad 1/2 watt resistor near V3. Amp sounds like new.
    Doc
+ Reply to Thread
  1. Yamaha T100C
    By Doc Stitches in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-26-2009, 06:16 PM
  2. Yamaha EMX660
    By kmiller1610 in forum Maintenance, Troubleshooting & Repair
    Last Post: 07-21-2009, 02:18 AM
  3. Yamaha T50 C
    By lowell in forum Theory & Design
    Last Post: 03-10-2009, 01:24 AM
  4. Yamaha wiring
    By luis in forum Guitar Tech
    Last Post: 10-13-2008, 02:41 PM
  5. Yamaha P7000S
    By Analog Mike in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-26-2008, 09:37 PM
