Results 1 to 9 of 9
Thread: Chassis Alterations
    Dec 2006
    York, PA
    322
    Chassis Alterations
    I have gutted a Peavey Bandit 1x12 and I am in the process of making a 2 channel all tube amp. My question concerns the front panel holes. How would I go about filling in the holes and redrilling the holes I need? Would bondo work? The chassis has a hi and low input holes which are vertical but I am just going to have one input so I want to fill those in. And then there are nine holes drilled but I need 12 and the chassis can easily fit all 12 plus the input but the current spacing of the bandit holes will not work. Any suggestions?
    Oct 2006
    Toronto
    151
    Thats tough.. I am sure bondo would hold normally, but once you thin it out so it is the same thickness as the metal chassis, it's not going to be very strong at all.
    My second hobby being arcade game collectiong/restoring it reminds me of dealing with a crappy Control panel on a conversion game. most of us put a new panel over the old one, and re-drill the holes. Bondo only works if you let it be thick enough to have strength.
    theres no way you could re-use the bandit holes?
    Old Timer defaced's Avatar
    Dec 2006
    York Pa
    1,394
    Give it to your welder friend to saw off and weld on an new, shiny, hole-less piece. But I'd need an empty chassis for that.
    No, I wouldn't use bondo. I would do the new panel over old panel axpro mentions.
    -Mike
    Dec 2006
    York, PA
    322
    Great! I am going to give him a call. Thanks Bro. Sure beats compromising the amp vision just to use the previous holes.
    Old Timer olddawg's Avatar
    Dec 2007
    Carlsbad, CA and Kona, HI
    2,397
    Usually you can simply cut a new panel to go over the old one. The nuts and washers for the pots an jacks will hold it in place. You can also paint it, silk screen, label, whatever while you are at it.
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    9,434
    In the long run it might end up being less work just to bend and punch a new 2mm aluminum chassis, obviously same exact size.
    You should discard original Peavey top screws and use longer pass-through bolts+nuts/washers la old Twin.
    That structure will be strong enough and can even be CNC milled before holding.
    You can have it anodized (usually black but maybe red or blue) and silver letters be laser-engraved.
    Looks would be killer.
  7. #7
    Dec 2006
    York, PA
    322
    Where can I get a chassis anodized and laser engraved? I like this idea. I can get my welder buddy, aka defaced, to fit a new front panel but I would love to get it silk screened or laser engraved.
  8. #8
    Oct 2007
    9,434
    Hi chunkitup.
    I don't know where you live.
    On a big industrial city or close to it, you should have averything available, otherwise you'll have to search a little.
    Just to have an idea of what I'm talking about, look at:
    Prodigy Engineering - Services: Laser Engraving Photo Gallery
    If you like it, read this thread:
    Laser Engraving Services for Panels
    If you have to deal through the mail, you do not need to send your chassis back and forth, just make a relatively thin front panel plate which goes over the actual chassis, held by jack and pot nuts as suggested below.
    Of course you can have a backpanel made too, also a plate with your personal mark to fix over the grill cloth.
    For laser engravers close to you, search for engravers that do sports prizes and the like. You can buy pre-anodized aluminum strips in various widths, cut to length, but you have to be very careful when drilling to avoid scratching the surface, there's no touch-up available as in painted surfaces.
    Results will blow your mind.
    Specifically Guitar Amp Plates (expensive):
    Amplates.com Gallery
    Have fun.
  9. #9
    Dec 2006
    York Pa
    1,394
    York Sheet Metal can laser cut and engrave Aluminum. 3/16" max thickness for cutting.
    AMZ manufacturing Corp. can do anodizing
    I don't know if either will be cost effective, but the guys we share a building with use these two companies alot for work.
    -Mike
  1. Chassis? Cheap chassis?
    By Satamax in forum Guitar Amps
    Last Post: 07-20-2009, 09:29 AM
  2. 55VAC on Chassis?
    By chipaudette in forum Other Amps
    Last Post: 01-14-2009, 03:59 PM
  3. Is a chassis bracket necessary
    By lmolter in forum Tweed Builders
    Last Post: 10-14-2008, 09:35 AM
  4. Removing the chassis...
    By EETStudent in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-18-2008, 11:20 PM
  5. custom chassis
    By scole in forum Theory & Design
    Last Post: 09-16-2007, 09:43 PM
