Results 1 to 12 of 12
Thread: 1 Tube Reverb
    Dec 2006
    York, PA
    238
    1 Tube Reverb
    I have a friend who wants reverb in an amp I built him. The problem is I have only 1 tube available and I noticed most reverbs need 3 triodes. Could someone throw me a schematic for reverb. The clean channel is your standard blackface circuit and the tank that I have is Accutronics 9AB3C1B long decay.
    Oct 2009
    44
    There's this thread on Ampgarage where a one-tube reverb is discussed using an ECL-xx series tube for both driver and recovery.
    Supporting Member txstrat's Avatar
    Mar 2008
    Germany
    1,225
    I've tried this one tube reverb (see pic). Got the schem from our member tubenit (thanks again).
    I left out the first pot and replaced it with a standard 1M grid leak resistor.
    Works great. The reverb is not as lush as in a regular fender circuit but wet enough if you don't do surf music. If you still want more reverb you could change the 330k resistor to 270k or something.
    Also the taper of the pot is even and smooth (I've used 1 meg audio).
    Works in other circuits as well. Just put it right before the PI.
    Dec 2006
    York, PA
    238
    Ok so I pulled out TuT1 and most reverbs use 2 tubes or 4 triodes. Now I can modify my clean circuit and free up 1 triode for a total of 3. How could I set up the reverb driver to only use 1 triode and then have 1 triode for the return and 1 for the mix. Or I might just try the scheme from txstrat. My buddy doesnt do surf music he just wants some depth.
    Mar 2008
    Germany
    1,225
    If you need a sound clip to decide if the reverb is lush enough, this is what tubenit posted as link:
    Music page of Jeff S S - MP3 music page on SoundClick
    Listen two minutes into "rainy blues".
    Senior Member hasserl's Avatar
    978
    Check this schematic: http://www.carvinmuseum.com/pdf/amps...r%20REV-E1.pdf
    It uses a 1 tube reverb and it works quite well, if not Fenderish, still provides way more verb than I use.
  7. #7
    Mar 2008
    Germany
    1,225
    Hasserl
    That looks good especially because it would spare a transformer. You got any soundclips?
    Have you tried it with no recovery triode before the PI?
  8. #8
    978
    Quote Originally Posted by txstrat View Post
    Hasserl
    No clips of the verb, but I could probably come up with one. That is a Carvin amp circuit, I've done a lot of mods to it, but not to the reverb.
  9. #9
    Mar 2008
    Germany
    1,225
    Would be great listening to it at "normal" and full verb settings.
  10. #10
    Member Alexander's Avatar
    Aug 2006
    Western New York
    48
    sleeper 1-tube reverb tube; JJ12DW7
    Hey TXSTRAT,
    Try your same circuit but with 'AU' triode (pins 1,2,3/P-G-K) driving xfmr from JJ12DW7/ECC832, just keep plate volts at 300-325vdc max. Those 'AU' triodes crank out close to 5W, drive pan much better than a 12AX7 triode. But still not surf reverb but will make 99% of reverb users happy. Use a 1M dwell pot on front end of circuit for great 1-tube/2-knob reverb!
    Cheers,
    Alexander
    Retrodyne Amplification
  11. #11
    Mar 2008
    Germany
    1,225
    Hey Alex,
    thanks alot for your hint.
    It never came to my mind to use a 12DW7 although I have used it in one of my builds.
    I'll definitely try it. Do you think I can keep the grid leak and plate resistors? Voltage now is around 255v?
  12. #12
    Aug 2006
    Western New York
    48
    mo' verb details
    I'm assuming your 1st plate is connected to the typical Fender reverb xfmr; they're usually set up for paralleled 12AT7, a single 12AU7 triode is about half that Z but they still seem to work well and have good life as long as you're not whackin' them with 400V like in a typical fender BF/SF amp. Use a bigger cathode R, IIRC 3.3k/1W works well, and use no bigger than 1uF/50V bypass cap, we don't want to amplify bass freqs in the pan circuit! smaller is better here!
    In lieu of 220k-1M grid load, why not use 1M or 500kA pot for reverb 'depth/dwell' control? This way you get 1-tube, 2-knob reverb!
    The 'recovery' amp side of the 12DW7 uses the same 82-100k plate R, .001 coupler to PI or blend/level pot. Consider it 1/2 12AX7.
    HTH,
    Cheers,
    Alexander
  1. 6GE8 as reverb tube, etc.?
    By Ray Ivers in forum Theory & Design
    Last Post: 08-26-2012, 02:31 PM
  2. Fender Pro Tube Pro Reverb - Dead Tremolo and Noisy Reverb
    By pmwalk in forum Maintenance, Troubleshooting & Repair
    Last Post: 12-09-2009, 10:54 PM
  3. What's the best reverb tube/circuit?
    By PRNDL in forum Theory & Design
    Last Post: 06-17-2009, 06:33 AM
  4. Reverb tube redplating
    By MickeyB in forum Maintenance, Troubleshooting & Repair
    Last Post: 03-08-2008, 01:57 PM
  5. deluxe reverb tube q
    By samgomez141 in forum Maintenance, Troubleshooting & Repair
    Last Post: 04-26-2007, 05:16 AM
