Originally Posted by
MWJB
Lowest note on an A harp is 220Hz, you want the amp to reproduce an octave below for full harmonics, bear in mind that many players also like Low F (176Hz) & similar harps...in short the amp/speakers should shelve the low end around <90Hz mark...the difference between that and 100Hz is tangible. Nothing worse than picking up a Low F or, G harp and have your 1st position low notes come out all hollow, tinny & monotonic because the amp only reproduces the higher harmonics.
"With all that info available on the web it's really hard to tell the difference between fact, myth and personal taste. Even pro builders sometimes get into arguments about this." - most of the guys producing "harp" amps have a quite personalised sound in their heads, subsequently many veer off the 'middle ground' kind of sound you typically get with a Fender...it just depends which side of the middle ground you like to stand. If you like cathode bias (Meteor), you're not going to buy a Sonny Jr 410 or a HarpKing - conversely if you need an amp to deliver short punchy phrases & really throw out chromatic, stiffer fixed bias might be preferable. Old & reproduction Fenders are still the most popular amps used for harp on stage.
